Power window only down
Old Jul 9, 2007 | 10:12 AM
g0ni's Avatar
Default Power window only down
I recently picked up a set of EX doors to swap out the internals into my manual doors. Drivers side was perfect, no problems... passenger side only goes down though... When I put a wire tester into the "up" wire between the switch and motor, it shows a signal when I hit up on the switch, but I get nothing from the motor. Does that mean switch is bad, motor is bad, or wiring from switch to motor is still bad? Down works perfect.
Old Jul 9, 2007 | 01:04 PM
quapouh's Avatar
Default Re: Power window only down (g0ni)
maybe you forgot to compress the spring assist on the passenger side ... motor by itself it to weak to up-it
my 0.02
gerbsgsr
Nov 17, 2010 06:19 PM
jds113
Aug 7, 2010 05:04 PM
