vtec pressure valve? (vid) need help
Old Jul 9, 2007 | 05:32 AM
NiK's Avatar
NiK
Default vtec pressure valve? (vid) need help
Cel is coming on (code22) when hitting vtec, i just did an oil change and there are no visable leaks.. the block was painted blue by previous owner who rebuilt it.. so i would see a leak if there was one. it doesnt burn oil either. also around 4.5k it throws out a little grayish smoke is that normal?
http://www.youtube.com/watch?v=MDvcF6YHyxs
Old Jul 9, 2007 | 07:39 AM
Boosted4life's Avatar
Default Re: vtec pressure valve? (vid) need help (NiK)
U may want to clean clean the vtec gasket. It may have a little debre or dirt which may block a little oil blockage. Also restart the ECU.
Old Jul 9, 2007 | 08:29 AM
95ProjectEJ1's Avatar
Default Re: vtec pressure valve? (slow guy)
new filters from Honda I believe run about $25 for the spool valve filter/gasket and the top gasket.
Old Jul 9, 2007 | 03:09 PM
NiK's Avatar
NiK
Default Re: vtec pressure valve? (95ProjectEJ1)
should i take the vtec silinoid apart and clean it ? i took it off the head when i replaced the intake mani gasket. and cleaned it a bit but i never took it apart
Old Jul 10, 2007 | 04:33 AM
NiK's Avatar
NiK
Default Re: vtec pressure valve? (NiK)
bump
PatrickGSR94
Jan 21, 2025 11:18 AM
Proud Virginian
Jun 20, 2022 06:59 AM
Master23
17
Apr 1, 2018 08:48 AM
3k9civic
Apr 24, 2005 04:39 PM
bboylito
Mar 3, 2005 04:14 AM
