ls/vtec bulid
Old Jul 8, 2007 | 07:01 PM
jordan2305's Avatar
Default ls/vtec bulid
what pistions should i use ls or b16
Old Jul 8, 2007 | 07:04 PM
93egSLEEPER's Avatar
Default Re: ls/vtec bulid (jordan2305)
well if your doing a LS vtec then you use the LS block and b16 head... if i understand a LS VTEC correctly thats hows it done...so ls pistons
Old Jul 8, 2007 | 07:13 PM
Papi4baby's Avatar
B16 are too small, you have to use LS or GSR pistons i believe. The only thing you can use about the B16 is the head.
Old Jul 8, 2007 | 07:30 PM
speedooo's Avatar
Default Re: (Papi4baby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Papi4baby &raquo;</TD></TR><TR><TD CLASS="quote">B16 are too small, you have to use LS or GSR pistons i believe. The only thing you can use about the B16 is the head.</TD></TR></TABLE>
all b series are 81mm bore except b20. if youre going na use b16 psitons, ls pistons for boost
Old Jul 8, 2007 | 07:32 PM
Slowass2dr's Avatar
u can use any b-series except b20, the best in my opinoin are the ctr pistons found in a b16b, the yeild the highest compression.....i had a motor with compression something like 14:1 using ctr pistons(not oem) but with oem ctr piston u could expect something like 12:1 to 13:1+ depending on setup
datnigabluberry
14
Nov 21, 2006 06:34 PM
prcrx124
May 18, 2004 11:29 PM
roc
Nov 9, 2003 07:21 AM
94GeeZR
Feb 14, 2003 12:24 PM
