Which to choose from? Build LS block or buy b20z?
Old Jun 7, 2002 | 10:45 PM
InfamousRS's Avatar
Default Which to choose from? Build LS block or buy b20z?
I can't decide what I want to do at this point.
Here are my options:
Keep my current LS block
Buy ITR pistons
ITR/CTR cams
Do full rebuild
Tune w/Hondata
Or
Buy stock b20z
Install ARP rod bolts
Install block girdle
ITR/CTR cams
Tune w/Hondata
Either way, it will be with my p&p Vtec head. If I keep my LS block, and just do a rebuild w/ITR pistons, my compression will be just over 12:1. If I get the b20z, the compression will be about 10.6:1 with my head (milled .020).
Either way, it will cost about the same. Which one would make more power?
Old Jun 8, 2002 | 07:14 AM
InfamousRS's Avatar
Default Re: Which to choose from? Build LS block or buy b20z? (InfamousRS)
anyone?
Old Jun 8, 2002 | 10:04 AM
daver's Avatar
Well, i think the 2.0L block will give you more low end tork even with the higher cr ls setup. To me low end is everything, so i'd say the crv setup. The low piston to valve clearance thing scares me tho.
My crv engine is so close now i can almost smell it.
Old Jun 8, 2002 | 09:50 PM
decypha's Avatar
damn..im in the same boat..and i cant decide on a fully built LS or B20...
id go B20...youll have a newer motor and a spare to sell or keep
Old Jun 10, 2002 | 09:49 AM
B-series Assassin's Avatar
I'd get the 2 liter block.
Old Jun 10, 2002 | 05:35 PM
fsarfino's Avatar
Default Re: Which to choose from? Build LS block or buy b20z? (B-series Assassin)
re-sleeve Ls block to 84.5mm for 2.0
Old Jun 10, 2002 | 08:45 PM
InfamousRS's Avatar
Default Re: Which to choose from? Build LS block or buy b20z? (fsarfino)
I would LOVE to do that, but unless I buy another block I would have to be without my car for at least a month.
I would go 86mm though if I decided to have the block sleeved!
[Modified by InfamousRS, 9:45 PM 6/10/2002]
Old Jun 11, 2002 | 10:26 AM
Anyotherone's Avatar
Woudn't 86mm make the walls to thin?
Old Jun 11, 2002 | 11:28 AM
InfamousRS's Avatar
Default Re: Which to choose from? Build LS block or buy b20z? (Anyotherone)
Golden eagle claims that their sleeves will still seal up to 87mm. My friend just got a block back from them in 86mm and it looks AWSOME!!!!!!
Old Jun 11, 2002 | 12:49 PM
fsarfino's Avatar
you could always buy a LS bottom end for like 350.00 or less try car-parts.com
Old Jun 11, 2002 | 02:38 PM
InfamousRS's Avatar
LS block: $350
Sleevs: $750
Bore & Hone: $125
Shipping: $100
Pistons: $550
Rods: $300
Balncing: $125
Bearings: $200
Gskets: $175
And a bunch of other stuff.
It would cost ALOT to turn my LS into a 2.0!
Old Jun 11, 2002 | 07:10 PM
ExospeedAMcrx's Avatar
it would cost a bit more, but is stronger since its already sleeved.
the b20 will stil lbe stock sleeves.
Old Jun 12, 2002 | 05:02 AM
BROOD's Avatar
Not with GE sleeves. But your headgasket sealing on the other hand will be touchy. I would not go over 85mm bores on a street engine. Leave the 86mm and larger bores to the race engines.
simple4012
Nov 6, 2012 08:33 AM
haroldthefly91crx
Nov 23, 2007 01:09 PM
trucdoken
Mar 11, 2005 08:46 PM
PowerHouse
Nov 16, 2004 04:04 PM
94integrablur
May 2, 2002 06:08 AM
