Studder Problem
Old Jul 8, 2007 | 05:52 PM
95civickid's Avatar
Default Studder Problem
Ok i have a B16A2 motor and i have a studdering problem in lower RPM's but it seems Fine after 4000 mostly 1st-3rd gear i have MSD ignition and its been on for a while and i havent had problems in the past.... but anyway this is what ive done so far when the problem occured NEW MSD Cap New OEM Rotor New NGK Spark Plugs, New Wires... after all that its gotten better but it still Bogs my boy said it could be the O2 also my Crank position Sensor isnt hooked up could that be a factor??? thanks in advance...
Old Jul 8, 2007 | 08:10 PM
95civickid's Avatar
bump... anybody???
Old Jul 8, 2007 | 08:25 PM
mckrank313's Avatar
Default Re: (95civickid)
my o2's just went out... and i'm having the same problem so it could be that...
but the cps could do the same thing.... are you throwing any codes and if so which ones... i mean obviously the one for the cps but are you throwing any other codes
cuz if you have that then we can help you diagnose your problem better
Old Jul 9, 2007 | 06:16 AM
95civickid's Avatar
thanks... could there be anything else to look at as well?
Old Jul 9, 2007 | 01:02 PM
mckrank313's Avatar
i would just start with the o2's and the crank sensor... after you fix that if you still have the problem see if you are throwing any cel's and if you are diagnose new problem from there...
good luck
Old Jul 9, 2007 | 06:51 PM
95civickid's Avatar
but would the O2's cause a Bog...?
Old Jul 9, 2007 | 06:53 PM
ke98248's Avatar
shitty fuel filter, clogged fuel injectors. poor fuel pump (not working well)
azn_ignite
Jul 23, 2009 02:36 PM
pork
Nov 11, 2007 08:20 PM
CompanyFlow
Acura TL, RL & ZDX
Apr 5, 2007 10:26 PM
ThatRicerDaniel
Feb 3, 2003 10:53 AM
