my b20 vtec dyno day
Old Jul 8, 2007 | 05:28 PM
ferio82's Avatar
Default my b20 vtec dyno day
so after finally upgrading injectors from 440 to 750 i finally decided to take my car to get tuned. i had a hondata s300 installed/tuned. We were only able to test it at 6 lbs of boost as i had no boost controller available and this is what it made. car runs real smooth now and less rich than it did before so im much happier. this is what i got
b20b block
stock sleeves
je 9.0:1 pistons
eagle rods
b18c1 head
stage 3 port/polish with valve job 3 angle
itr cams
itr valve springs
ss valves
skunk 2 camgears
stock i.m
rc eng. 750cc injectors
aem fuel rail
msd fuel pump
hondata s300
random manifold
garett gt3076r .82 hotside
38mm tial wastegate
2.5" exhaust
this is what i made at 6lbs boost
207 hp
170 torque
Old Jul 8, 2007 | 05:32 PM
Turbocivic94's Avatar
Default Re: my b20 vtec dyno day (ferio82)
good power, why on 6psi?
Old Jul 8, 2007 | 05:33 PM
ferio82's Avatar
Default Re: my b20 vtec dyno day (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">good power, why on 6psi?</TD></TR></TABLE>
thanks, didnt have 3 bar map sensor installed and we had no boost controller
Old Jul 8, 2007 | 05:34 PM
integraRS-T's Avatar
it looks like u only gained 40-50whp at 6 psi
Old Jul 8, 2007 | 05:38 PM
ferio82's Avatar
Default Re: (rsracer)
yeah im gonna have to fo back after i get thos misc. things. im shooting for 15 lbs next time.
Old Jul 8, 2007 | 05:42 PM
Default Re: (ferio82)
a stock pump will die out after 5k rpm on boost and since u pusht it for 2 weeks it prob. died
Old Jul 8, 2007 | 05:43 PM
sorry wrong post bout the fuel pump
Old Jul 8, 2007 | 05:55 PM
*Boostwerks*'s Avatar
Hrm. seems a little low. I remember someone making over 300whp @10psi with the same turbo on a stock B16.
Old Jul 8, 2007 | 06:08 PM
92redhatch's Avatar
seems very low.
Old Jul 8, 2007 | 06:27 PM
Default Re: (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">seems very low. </TD></TR></TABLE>
Yeah thats pretty much a built N/A motor dyno.
Old Jul 8, 2007 | 06:35 PM
ferio82's Avatar
Default Re: (Boostwerks.com)
hmmmmm, what do you think the problem could be????
Old Jul 8, 2007 | 06:40 PM
alpha's Avatar
I wouldnt worry about the numbers yet. Get everything you need to run more boost and hit the dyno again. Am I looking at it wrong. Looks like you only revved to 7000RPM on that pull?
Old Jul 8, 2007 | 08:29 PM
ferio82's Avatar
Default Re: my b20 vtec dyno day (alpha)
yeah he was only reving to 7000 to be on the safe side. i usually take it up to about 7900 then shift.
Old Jul 8, 2007 | 08:37 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
good displacement, good turbo, not so good numbers i have high hopes for my 76r tomorrow.
Old Jul 9, 2007 | 05:34 AM
ATYPR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio82 &raquo;</TD></TR><TR><TD CLASS="quote">
b20b block
stock sleeves
je 9.0:1 pistons
eagle rods
b18c1 head
itr cams........
207 hp
170 torque</TD></TR></TABLE>
I see a ton of money wasted on this set-up. The stock pistons and rods can handle more than the stock sleeves.
We did a b20vtec set-up about seven years ago using a stock b20b short block, a stock b16 head, ford motorsport 42# injectors, VAFC, and a old Revhard kit with a t3/t4b and it made 276whp on 9psi.
Old Jul 9, 2007 | 06:27 AM
dpetro1's Avatar
i feel like there is something wrong as well. just looking at the torque curve something seems off. a .82 30r should not be dropping torque at all especially 7k.
also where you tuning by the dyno wideband? if so it looks a bit lean.
Old Jul 9, 2007 | 06:38 AM
ferio82's Avatar
Default Re: (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUCATYPR &raquo;</TD></TR><TR><TD CLASS="quote">
do you think it is the tuning?? or maybe the motor is on the weaker side???? i upgraded to je pistons and better rods becuase i had already blown a piston so i figured i would upgrade, piston was blown with old setup i had before , #4 fuel injector went out and screwed it up
Old Jul 9, 2007 | 10:37 AM
ferio82's Avatar
i can feel a leak coming from the downpipe where the reducer from 3" to 2.5" is , think that could be the problem, maybe a loss of pressure. hmmmm, gonna have to get that checked out
Old Jul 9, 2007 | 12:49 PM
slammedNslowLS's Avatar
i know its only 6lbs, but that seems really week for a boosted b20. guess we'll she what it does at higher psi
Old Jul 9, 2007 | 01:45 PM
92redhatch's Avatar
Do a leak down and a compression test. also check your timing. i wonder what its at...
V-SPEC 1
Jul 9, 2012 01:38 PM
egboy94
Oct 19, 2010 07:03 PM
Spent
Aug 28, 2010 03:15 PM
Simple SOHC
18
Sep 17, 2004 03:27 AM
99b18
45
May 11, 2004 02:50 PM
