swap question, brain fart
Old Jul 8, 2007 | 05:04 PM
jasoncrashtech's Avatar
Default swap question, brain fart
i'm swapping a b18c ( obd2 ) into a 98 ex, i have a driverside si mount but will the t-mount and tranny mount of an ls work ? thanks
northwest xxx rootbeer here i come !!!!!
Old Jul 8, 2007 | 05:09 PM
forcefedferio's Avatar
Default Re: swap question, brain fart (jasoncrashtech)
tranny mount yes but i believe you will need the T bracket from an SI, if i remember correctly the LS one is about an inch too long
Old Jul 8, 2007 | 05:18 PM
Rock Meathammer's Avatar
Default Re: swap question, brain fart (forcefedferio)
Yes, you do need the t-bracket from an SI. Or a Del Sol dohc vtec. The Integra t-brackets will only allow two of the three bolts to be mounted, creating a swivel.
Old Jul 8, 2007 | 05:25 PM
teamworxek9's Avatar
you should be able to use all your stock mounts off the ex, but the rear one needs to be from a 99 00 si. unless its different from a b16 which i doubt.
Old Jul 8, 2007 | 05:37 PM
Default Re: (teamworxek9)
thanks! hopefully the tranny mount will work .
brasilstreet
Feb 28, 2004 07:48 AM
kingdan9034
Sep 1, 2003 07:29 PM
ransack
Feb 21, 2003 07:56 PM
98 Ek LsVtec
Jan 20, 2002 06:29 PM
