13" rim/slick and gsr front brakes??????????????????????
Old Jul 8, 2007 | 03:04 PM
jdmcoop's Avatar
Default 13" rim/slick and gsr front brakes??????????????????????
I have a set of 13" rims with slicks and they are catching on the caliper, I have gsr front and rear brakes.
I have read about people using spacers, is this the correct way and if it's okay where can I buy them.
Old Jul 8, 2007 | 03:12 PM
HYBRID_H@TCH's Avatar
Default Re: 13" rim/slick and gsr front brakes?????????????????????? (jdmcoop)
depends on how much room you need.
if its just catching by a little bit then 1/4 spacers from autoparts/tire store will be fine, but, if its hitting hard core you may want to hit up bogart and get there 1/2 spacers..
Old Jul 8, 2007 | 03:14 PM
jdmcoop's Avatar
Default Re: 13" rim/slick and gsr front brakes?????????????????????? (HYBRID_H@TCH)
you can just barely hear it when spinning the rims by hand. thanks for the help.
Old Jul 8, 2007 | 04:26 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYBRID_H@TCH &raquo;</TD></TR><TR><TD CLASS="quote">depends on how much room you need.
if its just catching by a little bit then 1/4 spacers from autoparts/tire store will be fine, but, if its hitting hard core you may want to hit up bogart and get there 1/2 spacers..</TD></TR></TABLE>
as long as you arent trying to put in an inch of back space, with the spacers youll be ok. as said above, if it is just a little bit, .250 spacers are fine.
Old Jul 8, 2007 | 05:51 PM
dday00si's Avatar
bogart spacers for me or get a rim with a
5" back space
what rims are you using?
BMaDOHC
Aug 7, 2007 01:23 PM
CRXBart
19
Nov 5, 2006 06:03 AM
GIANT
Mar 14, 2006 09:42 AM
vtecdamian
Sep 24, 2004 10:20 AM
Mr. Softee
Dec 25, 2001 04:59 PM
