Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Si Seats
Old Jul 8, 2007 | 03:14 AM
EM2Fiend's Avatar
Default Si Seats
i wanted to put ep3 si seats on my 04 coupe .... and was wondering if they bolt right on with the stock sliders or do i need to have the ep3 sliders? also will this need any customisation?
Old Jul 8, 2007 | 04:42 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: Si Seats (EM2Fiend)
As far as i recall they bolt up straight into three of the EM2 bolt holes and you have to drill out the 4th.
Old Jul 8, 2007 | 06:27 AM
fventura03's Avatar
^yep, one hole has to be made a little larger, you'll know what we're talking about once you get to that point.
Old Jul 8, 2007 | 07:23 AM
Curiouz_G's Avatar
1) youll need to drill like everyone said
2) youll need to use the stock belt clips off your EM2 seat
3) make sure you unplug your battery before unplugging anything under your seat. It'll save you the hassle of turning of your SRS light
Old Jul 8, 2007 | 07:47 PM
CivicInspired's Avatar
only one bolt doesnt match up.... i'll post up picts of what i did in a few...
Old Jul 8, 2007 | 07:52 PM
Default Re: (CivicInspired)
Drilled 1 hole on each side...
Put a long bolt all the way through w. a nut and lock washer on the other end...
i'll post up more picts of how they mount later... dont have any of those pcts
Old Jul 8, 2007 | 11:14 PM
Jon Vito's Avatar
or you could swap rails like i did, but then again i had to the seats i got had rails modified to fit an eg hatch
Old Jul 9, 2007 | 04:56 AM
even if you swap rails i think they still won't match up. the SI seats are wider. The rails angle out just a little bit. all the bolts matched up except the front outside bolts next to the door.... not sure how the back bolt lined up but not the front.
Old Jul 9, 2007 | 08:13 AM
LatinEM2's Avatar
I swaped the seat rails and brackets from the EM2 to the EP3 seats and every hole lined up. I even did a DIY thread on it.
Here's my link
https://honda-tech.com/zerothread?id=1959183
Old Jul 9, 2007 | 09:04 AM
Jon Vito's Avatar
yeah everything lined up perfectly and its a better fit than just using the ep3 rails
Old Jul 9, 2007 | 09:32 AM
well damn... lol i guess i could have saved me a lot of time by changing them out... i may just go ahead and do that.... thanks guys!
Old Jul 9, 2007 | 01:55 PM
EM2Fiend's Avatar
Default Re: (LatinEM1)
ok so what you do is put the em2 rails on the ep3 seats and it bolts all 4 holes perfectly?
Old Jul 10, 2007 | 04:46 PM
LatinEM2's Avatar
Default Re: (EM2Fiend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2Fiend &raquo;</TD></TR><TR><TD CLASS="quote">ok so what you do is put the em2 rails on the ep3 seats and it bolts all 4 holes perfectly?</TD></TR></TABLE>
yes
square_1
Dec 11, 2006 02:18 AM
Mr. Bagel
Honda S2000
Sep 22, 2004 12:47 AM
allzeeks
Nov 27, 2003 08:21 PM
wannab20hatch
May 2, 2002 12:01 AM
sneakychaos
10
Apr 23, 2002 03:43 PM
