Wow! What's up now?
Old Jul 7, 2007 | 06:04 PM
EX-T's Avatar
Default Wow! What's up now?
Well I guess I just have bad luck or something.
Today I was removing my tranny to fix my clutch and I hadn't unhooked the battery yet and when I went to take the starter out I touched one of the wires and it sparked so I immediately removed the battery cables at that point.
I get the tranny off and back on and when I go to start it, it won't start. All the dash lights come on but the check engine light, brake light and oil light are really dim while the other dash lights are just fine and at the same time there is a super wierd noise coming from my dash on the passenger side, like an electrical sound.
Also, I don't hear the fuel pump priming either and nor does the starter click. And if I turn the car all the way forward to start, the radiator cooling fan comes!?!
I checked all the fuses and they are all fine and tried jumping it off.
What's wrong withmy ish!?!??!?!?
Modified by EX-T at 9:25 PM 7/7/2007
Old Jul 7, 2007 | 06:06 PM
1992Si's Avatar
May be time for a new starter. How long did it spark?
Check battery voltage. do you have volt meter? If not take jumper cables. attach them to the battery. take the other ends and quickly tap them together. See if you have a good spark.
Old Jul 7, 2007 | 06:07 PM
EX-T's Avatar
Default Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">May be time for a new starter. How long did it spark?
Check all your fuses too.
It only sparked for like a millisecond.
Old Jul 7, 2007 | 06:13 PM
1992Si's Avatar
Try removing the starter and re-install it. It's worked for me.
Then think about buying a rebuilt starter in the near future.
Old Jul 7, 2007 | 06:14 PM
EX-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Try removing the starter and re-install it. It's worked for me.
Then think about buying a rebuilt starter in the near future.</TD></TR></TABLE>
Like take the wires off the starter and put them back on? I did that.
I think it's a fuse or relay or something.
Old Jul 7, 2007 | 06:23 PM
Tzer's Avatar
Can you try jump starting it?
I know yesterday in my truck I took a drive and after coming home for an hour I went to leave again. It clicked hard then nothing. I took the batt to the parts store and they tested it, and it was bad. They prorated it, brought home and installed and it's all good.
Hopefully it's something that simple, You've had a rough time here, you deserve a break :D
Old Jul 7, 2007 | 06:24 PM
EX-T's Avatar
Default Re: (Tzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tzer &raquo;</TD></TR><TR><TD CLASS="quote">Can you try jump starting it?
Hopefully it's something that simple, You've had a rough time here, you deserve a break :D</TD></TR></TABLE>
I did try to jump it off and it does the same thing.
Old Jul 7, 2007 | 06:25 PM
1992Si's Avatar
Default Re: (EX-T)
No because it's more work. I had to pull them all the way out of the car and then put them back in.
Yes them as in more then one time.
Don't ask me why. At least I didn't put the disc in backwards.
Sorry, couldn't pass that one up...LOL
Don't ever feel bad about doing something stupid on the car. We all have done most stupid things.
Even Earl told me he left the rotor out of the Dizzy one time, I didn't feel so bad after that. That's two times I know of...
Old Jul 7, 2007 | 07:09 PM
sauceja's Avatar
Could have fried the ecu. Could have fried the battery.
Did you check all fuses? I would replace the starter fuse anyway because some times a blown fuse looks good.
Old Jul 7, 2007 | 07:43 PM
94c1v1cex's Avatar
Default Re: (sauceja)
try push starting it... and make sure all your engine grounds are on... what kinda car/motor is it?
Old Jul 7, 2007 | 07:51 PM
95civiccpdx's Avatar
Default Re: (94c1v1cex)
gl check your main relay
Old Jul 7, 2007 | 09:52 PM
HCivicSi23's Avatar
Default Re: (95civiccpdx)
It's possible you short circuited a wire.
Old Jul 8, 2007 | 02:06 PM
EX-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex &raquo;</TD></TR><TR><TD CLASS="quote">try push starting it... and make sure all your engine grounds are on... what kinda car/motor is it?</TD></TR></TABLE>
Be sure you attach the ground that goes from the frame rail to the tranny! That fixed it! Thanks, buddy, I got into a rush and didn't hook this one up! Another for me!
Now the clutch won't engage at all!
teamitr
Jan 29, 2007 09:16 PM
slowcrxsib16
Aug 10, 2006 02:11 PM
zensoku207
Sep 7, 2004 03:50 PM
JToolz
Feb 14, 2004 11:49 AM
Lo-Buck EF
Aug 24, 2002 04:38 PM
