ATTN ANY ONE BUYING FROM JDM OF MIAMI
Old Jul 7, 2007 | 03:00 PM
egb16pg's Avatar
Default ATTN ANY ONE BUYING FROM JDM OF MIAMI
theres one thing that you should know when buying from jdm of miami,
DONT.
pm me why.
Modified by egb16pg at 7:53 PM 3/29/2008
Old Jul 7, 2007 | 03:36 PM
92redhatch's Avatar
jdm of miami? never heard of them. where in miami?
Old Jul 7, 2007 | 03:38 PM
egb16pg's Avatar
Default Re: (92redhatch)
they are in a warehouse by the new lexus dealership(by the zoo)
Old Jul 7, 2007 | 04:05 PM
Boostedb20EH2's Avatar
Default Re: (egb16pg)
Okay....
Why are you freaking out because your motor wont start. If you "built" it from the ground up shouldnt you have noticed anything odd during that. And two why should they warranty a motor someone built. How do they know good old bob didnt forget to check his clearances on his high compression motor. Why should they be responsible for that. And even if you did build it right, its probably something stupid in the ignition system or fuel area.
Old Jul 7, 2007 | 04:21 PM
philosofy1's Avatar
Default Re: ATTN ANY ONE BUYING FROM JDM OF MIAMI (egb16pg)
i've heard bad things about them too. i have a friend down in miami. i came up to my neck of the woods and was dissapointed in the crappy work they performed on my friends civic.
i would stay away from them too.
Old Jul 7, 2007 | 04:57 PM
lovey408's Avatar
Default Re: ATTN ANY ONE BUYING FROM JDM OF MIAMI (philosofy1)
why exactly doesnt it start? and did u get a compression test done b4 they sold u the motor?
Old Jul 7, 2007 | 05:12 PM
Mr_SARS's Avatar
I don't understand how it would take you 6 months to build up a motor. Did you buy the motor first, just to have it sit there while you were waiting on parts?
Why is your timing off? Did you "build" up an engine just to try and start it without setting and then double checking the timing?
Maybe you're the one that screwed up the engine when you were "building" it. I mean, it did take you half a year to finally finish it.
Old Jul 7, 2007 | 08:36 PM
egb16pg's Avatar
Default Re: ATTN ANY ONE BUYING FROM JDM OF MIAMI (Mr_SARS)
ftl
Modified by egb16pg at 7:54 PM 3/29/2008
Old Jul 7, 2007 | 08:45 PM
ke98248's Avatar
This belongs in the long official list of scammers if you believe you were scammed. Otherwise, this thread doesn't belong here. Read the rules for this area!
Old Jul 7, 2007 | 09:18 PM
lovey408's Avatar
Default Re: ATTN ANY ONE BUYING FROM JDM OF MIAMI (ke98248)
next time u buy a motor have them do a compresstion test on the motor so u dnt end up in this situation. u shuld be more prepared and aware b4 u decide to spend that much money on sumthng
Old Jul 7, 2007 | 09:34 PM
EG6LS's Avatar
Default Re: ATTN ANY ONE BUYING FROM JDM OF MIAMI (lovey408)
The 30 day start up warranty means you do the swap as is and if it doesn't start because of a mechanical problem they will replace. That's how I did it. Then I started moding the motor. But I also got mine from http://www.hmotorsonline.com which came with 30 day start up warranty.
Old Jul 7, 2007 | 10:23 PM
egb16pg's Avatar
Default Re: ATTN ANY ONE BUYING FROM JDM OF MIAMI (EG6LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lovey408 &raquo;</TD></TR><TR><TD CLASS="quote">next time u buy a motor have them do a compresstion test on the motor so u dnt end up in this situation. u shuld be more prepared and aware b4 u decide to spend that much money on sumthng</TD></TR></TABLE>
pfft. like there will be a next time. what can i say,at the moment i didnt know anything about buisness.
well at least now im wiser.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6LS &raquo;</TD></TR><TR><TD CLASS="quote">The 30 day start up warranty means you do the swap as is and if it doesn't start because of a mechanical problem they will replace. That's how I did it. Then I started moding the motor. But I also got mine from http://www.hmotorsonline.com which came with 30 day start up warranty. </TD></TR></TABLE>
no, i talked to the dude there and he said its only 30 days after the purchase date.
i really hope this helps someone out
Old Jul 7, 2007 | 10:35 PM
egb16pg's Avatar
Modified by egb16pg at 11:46 PM 7/7/2007
Old Jul 7, 2007 | 10:51 PM
egb16pg's Avatar
ftl
Modified by egb16pg at 7:55 PM 3/29/2008
Street Racer X
12
Apr 1, 2015 05:13 PM
forvendetta
Oct 29, 2007 03:39 PM
TEAM562racing
Oct 15, 2003 01:55 PM
BLK99VTECR
Aug 23, 2003 11:57 PM
IgniteTeg
Oct 30, 2002 12:34 PM
