brake caliper problem
Old Jun 7, 2002 | 07:28 PM
blackEF's Avatar
Default brake caliper problem
The brake caliper piston is frozen on the front right. Just wondering before we go try and take it off if there is a easier way to get it unfrozen without taking the whole caliper off, and cleaning the piston. Thanks
Old Jun 8, 2002 | 05:50 PM
kyler's Avatar
Default Re: brake caliper problem (blackEF)
nope.... once its frozen even if you get it unstuck the seals are likely dead, either rebuild with new rubber for $10 or reman-ed caliper for $40ish... i'd do reman though
Old Jun 8, 2002 | 07:37 PM
blackEF's Avatar
Default Re: brake caliper problem (kyler)
well the new problem is the upper bolt that hold the caliper on is frozen or i would have already gotten a new one for 7 bucks at the junk yard. But its no use when I cant get the old one off first.
Old Jun 8, 2002 | 08:10 PM
kyler's Avatar
try an impact or turn the hub out and get jiggy with a 17mm socket and 3ft of pipe? blowtorch and hammer?
PabloDiablo
May 30, 2007 06:45 PM
Lorolla
Nov 14, 2004 09:10 AM
blackEF
Jun 7, 2002 08:50 PM
wickedxbo1
Dec 31, 2001 10:02 AM
