94 Accord Squeeking Driver Side Suspension.
I searched with no avail so I am making a new thread. My suspension is squeeking like a bitch you have no idea. Every bump i hit it squeeks, every time i turn the wheel it squeeks. I tried to spray some lubricant in there to see if it stops, and it stops for like 10 secs. Anyone have any ideas, I don't even want to drive the car with it like this... Thanks Alot !
ps: car is stock... no cut springs or crap like that
Try spraying some silicone lube into the sway bar bushings. If it shuts it up, you can pull the bushings and lube the inside of them with silicone grease.
This link might help you;
http://members.troublecodes.ne...s.htm
I am about to try this in ten minutes... thanks alot seems like an easy little fix... i hope that is the solution, which would seem pretty good. Ill get back to the thread with the results... Thanks!
Sadly it didn't stop which i thought would be the problem since the bushings were bone dry and also one of the bolts were so rusted it broke in half so only one bolt is holding the bushing on....i dont see it as a problem but the squeek is still there never the less... any other ideas? Thanks
Dr. Design
Feb 26, 2004 12:44 PM
Bonga
Aug 6, 2002 06:51 PM
