replacing a break caliper on a honda prelude
Old Jul 7, 2007 | 11:02 AM
kaoskaw's Avatar
Default replacing a break caliper on a honda prelude
I have a bad caliper on the rear passenager side of my 92' honda prelude. I got a replacement kit but don't know what exactly to do. I am not sure if I need to bleed the breaks after I cange the caliper and the pads.
Old Jul 7, 2007 | 11:05 AM
xxmastermindxx's Avatar
Default Re: replacing a break caliper on a honda prelude (kaoskaw)
you pretty much bleed any time you do anything to your brakes, unless you are just topping off your fluid.
Old Jul 7, 2007 | 12:11 PM
lude98SH's Avatar
Default Re: replacing a break caliper on a honda prelude (xxmastermindxx)
just remove the brake line there should be some washers there, the kit should have those replacement washers i believe. Remove olb caliper. Then intall new caliper. And then bleed it.
At the shop i work at we bleed everytime we do brakes.
Old Jul 7, 2007 | 07:37 PM
M2B4's Avatar
Default Re: replacing a break caliper on a honda prelude (lude98SH)
yeah its really simple just look at it and it will come to you. you will need to bleed.
Old Jul 8, 2007 | 09:23 AM
mattsnooz's Avatar
Default Re: replacing a break caliper on a honda prelude (M2B4)
maybe he means the *repair* kit? the ones that come with new seals, lubricant, ect.
Yes you do bleed. All four, always. I think its Passanger Rear, Driver Rear, Passanger Front, Driver Front, I'm sure some one else here would know for sure.
Old Jul 8, 2007 | 10:09 AM
NNV's Avatar
NNV
brake > break *doh* just fyi
neil willis
Suspension & Brakes
May 13, 2018 02:51 PM
5thGeneration
Nov 17, 2007 10:35 PM
support1
Mar 11, 2006 12:47 PM
siffredi
Nov 7, 2005 12:49 PM
EVOTHIS
Nov 27, 2002 01:02 PM
