Brake Fade Question
All right so my brakes are acting pretty inconsistent on hot days especially,they will fade like there is air in the lines,but I have bled them to no avail.Its wierd because if I stomp the brake or keep pretty taught pressure on it it will hold fine,but If I slowly apply pressure,like u would on any normal braking,it will slowsly slip to the floor,not all the way way,but pretty close.
So my question is do u think its seal on my master cylinder ,and if so is it re buildable,or is it one of those parts that u just replace.Im pretty sure the local machine shop/ parts house sells a rebuild kit for it,but not positive,I was looking for some insight first.Thanks
By the way I searched and found many similar threads,but none with the same problem as I am experiencing.
This just happened to me.
If you're not loosing fluid then I would say its probably the brake master cylinder.
Beware! Mine did this right after I lost my clutch. Hopefully you've only got the one problem.
Azxster
Oct 27, 2007 08:26 PM
Batoutahell
Apr 14, 2003 11:26 AM
