EM1 lug nut question:
Can anyone tell me the correct size socket to use on my OEM lug nuts (99' si)? Have tried several sockets and the closest fit seems to be a 19mm however it's fairly loose (afraid it will strip with pressure)!
Metric or standard?
Thanx!
Metric or standard?
Thanx!
19 mm is the proper size, and shouldn't be so loose that it seems like it's going to strip. If it's that loose, is it possible that someone at some point replaced your lug nuts with wrong-sized ones? Lug nuts are cheap; you can buy them at your local Autozone for around $1.19 each. Remember to make sure you get the ones with the ball-shaped seating area, for stock wheels.
