LS Non-vtec Build
Old Jul 7, 2007 | 09:08 AM
votoms888's Avatar
Default LS Non-vtec Build
My Plans:
Stock B18A1 Block (hot tanked and honed)
Stock Head (maybe some hand porting and polishing)
Crower 404's
Crower Springs and Retainers (or Brian Crower equivalent)
PR3 Pistons (10.8:1 CR)
Arias Forged LS Rods
Skunk2 Intake Manifold (still undecided on whether or not it is worth it)
Skunk2 TB (still undecided on whether or not it is worth it)
PR4 ECU running Turbo Edit
Please post some opinions.
Old Jul 7, 2007 | 01:27 PM
b19coupe's Avatar
Default Re: LS Non-vtec Build (votoms888)
Since you are running Crower 404's, go with the Skunk or Blox intake manifold; the stock LS IM is going to choke the top end where those cams want to run. Get a good header and exhaust to help the engine breathe too.
Old Jul 7, 2007 | 04:52 PM
votoms888's Avatar
Default Re: LS Non-vtec Build (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Since you are running Crower 404's, go with the Skunk or Blox intake manifold; the stock LS IM is going to choke the top end where those cams want to run. Get a good header and exhaust to help the engine breathe too.</TD></TR></TABLE>
That is what I guessed. I already have an exhaust. What header to do you recommend? I don't wanna spend too much on that. I am trying to work within a strict budget.
Old Jul 7, 2007 | 05:47 PM
b19coupe's Avatar
The JDM ITR 4-1 and DC JDM 4-1 are decent, or one of the SMSP or Hytech knock off headers which make o.k. power.
Old Jul 7, 2007 | 10:04 PM
votoms888's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">The JDM ITR 4-1 and DC JDM 4-1 are decent, or one of the SMSP or Hytech knock off headers which make o.k. power.</TD></TR></TABLE>
Will these fit on my B18A? It is in a 1991 DB1. I was told that I need one specific to 90-91 integra. 92-93 use different headers and exhaust.
Modified by votoms888 at 10:30 PM 7/8/2007
Old Jul 9, 2007 | 02:51 AM
143MYVTECEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by votoms888 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by votoms888 at 10:30 PM 7/8/2007</TD></TR></TABLE>
Interested too.. Can you use a vtec exhaust manifold on a non-vtec head?
Old Jul 9, 2007 | 07:02 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by votoms888 &raquo;</TD></TR><TR><TD CLASS="quote">Will these fit on my B18A? It is in a 1991 DB1. I was told that I need one specific to 90-91 integra. 92-93 use different headers and exhaust.
They will bolt to the head, not sure about chassis fitment. Sorry.
Old Jul 10, 2007 | 10:07 PM
kartman5's Avatar
Just dynoed my sons LS at Churches with nearly same mods. Dynoed at
162 hp and 130 torque. Need to bore out the TB and get a better header.
Will re dyno soon. Good luck! ( used Hondata S 100 )
Old Jul 10, 2007 | 10:35 PM
votoms888's Avatar
Default Re: LS Non-vtec Build (kartman5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kartman5 &raquo;</TD></TR><TR><TD CLASS="quote">Just dynoed my sons LS at Churches with nearly same mods. Dynoed at
Will re dyno soon. Good luck! ( used Hondata S 100 )</TD></TR></TABLE>
Really? Nice!!! My plans are to get a new blox or SK2 TB. Since it will be off. I would rather get a new one instead.
Old Jul 10, 2007 | 10:36 PM
votoms888's Avatar
Is it worth it to go 2.0L? I have a guy that has two blocks he can sell me.
1:
JG open deck sleeved block. Currently 85mm bore. Needs a rebore so might have to go 86mm
2:
Stock B20B block
Which one would you guys suggest? Or should I just stay with LS 1.8L?
Old Jul 10, 2007 | 10:52 PM
kartman5's Avatar
Default Re: (votoms888)
Best guys to ask would be Sean or Todd at Churches. They have a great deal
of experience with these builds. Good luck!
jdmboy94
Jun 4, 2009 08:10 PM
drifter19
Apr 6, 2008 10:16 AM
Bjorn20
Jun 20, 2006 02:39 PM
jfteg
Aug 16, 2004 07:57 PM
SOHCVTECx2
Jul 13, 2004 04:03 PM
