Transmission whine
I need some advice.. my tranny whines when i idle. but when i put the clutch in it stops. might it be the throw out baring? if so would it be smart just to replace the whole clutch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkLanta »</TD></TR><TR><TD CLASS="quote">I need some advice.. my tranny whines when i idle. but when i put the clutch in it stops. might it be the throw out baring? if so would it be smart just to replace the whole clutch?</TD></TR></TABLE>
Yes, that would be the throwout bearing. It can be changed separately if you don't need to change the clutch out. Should run about $50 or so from Honda.
why would i search if idon't know whats wrong with it?
geeze people "search" can't be helpful and tell me?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy »</TD></TR><TR><TD CLASS="quote">its not ur throwout bearing!
SEARCH & you will find out what bearing it really is...
this has been covered many times</TD></TR></TABLE>
If you know what it is, it takes just as much effort for you to post the information here as it does for you to flame the original poster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy »</TD></TR><TR><TD CLASS="quote">why does my post keep disappearing</TD></TR></TABLE>
Because you refuse to actually post something helpful and instead insist on being negative.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">ISB, I charge $80 to fix it
Ahhhh yes, ISB not TB.
Wanna come to WI and change out my mainshaft oil seal for that rate?
You'd have to pay all expenses incured along the way
ONLY 400 miles each way
My problem is working 6 days a week, I'll have two trannys going to Hoplland, MI soon. With work I can't road dawg like it used to.
