Were to run remote wire in 2007 Accord
Old Jul 7, 2007 | 08:27 AM
indyhondashine's Avatar
Default Were to run remote wire in 2007 Accord
Is there any risk running the remote wire into the fuse box? Say the one marked "ACC?"
Thanks
Al
Old Jul 7, 2007 | 08:32 AM
fcm's Avatar
fcm
Old Fart
Default Re: Were to run remote wire in 2007 Accord (indyhondashine)
No. 94
Old Jul 9, 2007 | 06:26 PM
taltares's Avatar
Don't run it in the fuse box. If ur running a stock deck u can tap into the ACC wire on the back of it. Put a fuse on the remote wire.
Old Jul 15, 2007 | 07:49 PM
sony224422's Avatar
Default Re: Were to run remote wire in 2007 Accord (taltares)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taltares &raquo;</TD></TR><TR><TD CLASS="quote">Don't run it in the fuse box. If ur running a stock deck u can tap into the ACC wire on the back of it. Put a fuse on the remote wire.</TD></TR></TABLE>
uh you do know that would just be taking it from the fusebox anyways. and theres no need for a fuse on the remote line.
Old Jul 15, 2007 | 08:28 PM
fcm's Avatar
fcm
Old Fart
Default Re: Were to run remote wire in 2007 Accord (sony224422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">
uh you do know that would just be taking it from the fusebox anyways. and theres no need for a fuse on the remote line. </TD></TR></TABLE>Well your right about the fuse box but you should always fuse a power lead as close to the source as possible, a 1A fuse is big enough for 2 or 3 amps. 94
Old Jul 16, 2007 | 09:39 AM
suspendedHatch's Avatar
Default Re: Were to run remote wire in 2007 Accord (fcm)
He probably means to do a fuse tap, and those suck.
Solder into the ignition harness accessory wire or preferably at the radio as was stated.
Old Jul 16, 2007 | 11:22 AM
fcm's Avatar
fcm
Old Fart
Default Re: Were to run remote wire in 2007 Accord (suspendedHatch)
"He probably means to do a fuse tap, and those suck" Ditto that, do not use a fuse tap. 94
Old Jul 16, 2007 | 02:57 PM
sony224422's Avatar
ehh, i don't see the point of fusing the remote..
Old Jul 16, 2007 | 04:03 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">ehh, i don't see the point of fusing the remote.. </TD></TR></TABLE> Whats not to see? It is a power wire, if it was connected to a HU the HUs fuse protects the wire and more then likely a 1A diode on the leads output.
Remember the fuse is there to protect the wire, even though the load, [amp turn on] may only be 100mA - 200mA, if there is a short it will draw whatever the wire can handle until it burns up. 94
Old Jul 16, 2007 | 09:45 PM
sony224422's Avatar
its a good point..
i just see it as another fuse to have to check.. i mean doesn't the headunit protect that wire? If not than maybe i'll start putting fuses on it..
Old Jul 17, 2007 | 05:15 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">if it was connected to a HU the HUs fuse protects the wire and more then likely a 1A diode on the leads output.</TD></TR></TABLE>Yes, if it is connected to the amp control output of a HU, or to the stock HUs acc. lead, connecting to an acc buss or a lead in the ign. harness is still fused, but the fuse will be a main fuse, 50A-80A or bigger, shorting even a 16ga trigger lead connected to a 50A fuse will burn the car to the ground before the fuse blows. 94
Old Jul 17, 2007 | 08:06 AM
sony224422's Avatar
i did not even think of that. thanks for the info
lazyweasal4
Audio / Security / Video
Dec 12, 2006 04:06 PM
Boarderx192
Dec 5, 2005 07:35 AM
Namtab_Reverof
13
Jan 9, 2005 12:42 PM
andyhoiho
May 29, 2004 07:58 AM
95gsr
Sep 18, 2001 09:25 AM
