ls/vtec gasket fitment question
Old Jul 7, 2007 | 07:09 AM
bnut510's Avatar
Default ls/vtec gasket fitment question
i have a ls/vtec motor im slapping together and i have a ls head gasket. im wondering about the fitment. it fits ok on the block but when i line it up to the b16 head, it doesnt seem like it matches with all the holes. is this ok or do i need to take it to the machine shop? sorry if this seems like a dumb question.
Old Jul 7, 2007 | 09:26 AM
bnut510's Avatar
Default Re: ls/vtec gasket fitment question (bnut510)
bump
Old Jul 7, 2007 | 09:30 AM
Boostfed's Avatar
New User
Yes it works, there are probably over 1 million LS/VTEC set ups using a stock LS headgasket
Now Cometic makes a gasket specifically for an LS/VTEC which they opened up the dowel pin holes more and some other **** they state lines up better yadda yadda
Old Jul 7, 2007 | 09:41 AM
bnut510's Avatar
Default Re: (Boostfed.com)
so the non-consistant match to the b16a head is ok? whats this im reading about modifying the dowel pins? im searching but the most im getting is thats what i need to do, so any ideas on how to do this? thanks for the reply
Old Jul 7, 2007 | 09:49 AM
Boostfed's Avatar
New User
Default Re: (bnut510)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bnut510 &raquo;</TD></TR><TR><TD CLASS="quote">so the non-consistant match to the b16a head is ok? whats this im reading about modifying the dowel pins? im searching but the most im getting is thats what i need to do, so any ideas on how to do this? thanks for the reply </TD></TR></TABLE>
Instead of modifying the dowel pin holes just get some LS/VTEC dowel pins, I have some in stock from Golden Eagle. $20 shipped man They are stepped dowels fat on one end and skinnyon the other, you can run them on the exhaust or intake side really but need to turn them over depending on what side you use.
Old Jul 7, 2007 | 10:26 AM
RC000E's Avatar
I used the B16 gasket on all the LS/vtecs I've built until my most recent one. The one I just did I used a Cometic LS gasket. Everything lined up fine, all I had to do was open up two holes in order to use the Golden Eagle ls/vtec dowel pins.
The LS/vtec dowels are designed to be used in the B16 dowel location, so a B16 gasket will sit over the pins, but if you use an LS gasket with the pins the holes where the dowels go will be too small, and they need opened up.
If the mismatch your referring to, is the slight mismatch to the large oil drain galleys, then that's not an issue...headgaskets don't match identically to all the galleys ever...but they match enough to seal obviously.
Old Jul 7, 2007 | 11:40 AM
blackeg's Avatar
Default Re: (RC000E)
you have to take out 2 of thee 4 little brass grommets that hold the 3 layers together. i think its the ones on the exhaust side but i could be mistaken
Old Jul 8, 2007 | 12:51 AM
methos713's Avatar
Default Re: (blackeg)
any pics?
Old Jul 8, 2007 | 07:06 AM
integraRS-T's Avatar
just get a cometic ls-v gasket
Old Jul 8, 2007 | 08:14 AM
bnut510's Avatar
Default Re: (methos713)
ill post some pics on some progress. i gotta get my camera out to take some so bare with me. sorry for not posting in the first post. i will re-edit asap.
i already have a stock ls gasket... which is y i didnt go with a cometic. besides, doesnt the cometic drop the compression a little? im actually gonna run a high compression build on this one, and maybe boost it to see what it can do.
after completing this ls/vtec setup, i will be moving my attention towards the b18c build for low comp, goals in the vicinity of 400hp.. nothing to crazy. ill keep it posted tho. thanks for the helpful replies
Old Jul 8, 2007 | 12:02 PM
u can get a oem cometic size i think its 0.30mm for ls motors
88.REX
Nov 17, 2009 08:46 AM
bnut510
Jul 7, 2007 06:53 PM
Kevin Cliff
Dec 12, 2003 12:07 PM
type autox
Oct 27, 2001 04:31 PM
