AEM Uego Wideband 6 in 1 Gauge - In stock ready to ship!
<FONT COLOR="blue"><FONT SIZE="4">AEM Uego Wideband 6 in 1 Gauge System</FONT></FONT>
<FONT SIZE="2">
Phearable.net utilizes aem uego products for all tuning services & in personal/customer vehicles.
Description:
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
Key Features:
- Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
- Does not oscillate AFR reading like narrow band sensors
- Easy to install & No laptop required for monitoring!
- Bosch sensor included
- Accurate to 0.1 AFR
- Reads in AFR or Lambda via a switch in back of gauge housing
- 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
- Integrated three-digit display reveals AFR or Lambda in real time
- User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
- Serial data stream included for output of AFR (RS 232)
- Works with AEM EMS, Hondata, Ectune, Neptune, Uberdata & more!
Recommended Wide Open Throttle Target Air Fuel Ratios On 91-93 Octane Vehicles:
All motor vehicles: 12.9-13.4:1 (Full Throttle)
Forced Induction Vehicles: 11.2-12.0:1 (Full Throttle)
Partial Throttle/Idle: 15.5:1 (Light Throttle) 14.7-13.6:1 (Partial to Mid Throttle)
There are many small variables involved in targeting your air/fuel ratios, the main idea is to ensure you are not running too rich or lean & making the safest & best power possible due to maintaining a proper amount of fuel to your motor at all times.
How hard is the AEM Uego to install?:
The AEM Uego is very easy to install.
The system only uses 4 wires: 12v, Ground, Signal, Serial
To datalog the 0-5 volt output you simply use the white wire in the harness with which ever system you are using i.e. hondata.
How long will it take for me to receive my order?:
Your order will be shipped within 1-3 business days.
Delivery time is 2-5 days on average via usps priority mail.
</FONT>
<FONT SIZE="4">Part #: 30-4100
Availability: In Stock Ready To Ship
Retail Price: $349.41
<FONT COLOR="red">Phearable.net Sale Price: $259.99</FONT>
</FONT>
<FONT SIZE="5">To order visit our website by clicking here!
</FONT>
<FONT SIZE="4">Click here to visit phearable.net</FONT>
Modified by mtber at 2:12 AM 7/13/2007
<FONT SIZE="2">
Description:
Key Features:
</FONT>
</FONT>
</FONT>
