ARP Bolts worth it?
Old Jul 6, 2007 | 08:58 PM
HatchSpeeD's Avatar
Default ARP Bolts worth it?
Finally installing my B16 transmission & ofcourse while it's out it well get a new clutch. Looking into action clutch (1md).
Anyway is it really worth getting arp flywheel/pp bolts? Should I just use the used oem ones? I'll be using a 8lb fidanza flyhweel.
Old Jul 6, 2007 | 10:00 PM
ToeJam's Avatar
Default Re: ARP Bolts worth it? (HatchSpeeD)
oem
Old Jul 7, 2007 | 05:58 AM
stumpyf4's Avatar
Default Re: ARP Bolts worth it? (toekneevwj)
The only place I substitute ARP stuff is where OEM stuff is one time use only. Head studs, main studs, etc. since ARP studs and bolts are reusable.
FYI; I blue loctite my flywheel bolts for peace of mind.
Old Jul 9, 2007 | 09:30 AM
HatchSpeeD's Avatar
So your saying the OEM flywheel & PP bolts will suffice for around 200whp on a 4puck/6puck unsprung clutch? If using locktite, will it change the torque reading while tightning them down?
Old Jul 9, 2007 | 03:58 PM
stumpyf4's Avatar
Default Re: (HatchSpeeD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchSpeeD &raquo;</TD></TR><TR><TD CLASS="quote">So your saying the OEM flywheel & PP bolts will suffice for around 200whp on a 4puck/6puck unsprung clutch? If using locktite, will it change the torque reading while tightning them down?</TD></TR></TABLE>
Yes... OEM will be fine for your application. I torque to spec. with Loctite and yes Loctite will effect the bolt torque, not much to be worried about IMHO.
Old Jul 9, 2007 | 04:10 PM
HatchSpeeD's Avatar
To compensate, should I just torque it down a little more?
Old Jul 14, 2007 | 04:46 PM
stumpyf4's Avatar
Just torque down to stock spec. You're actually putting more strain on the bolt using a lubricant for a given torque.
angrysmileyface
Sep 14, 2014 05:09 AM
ss396rat
10
May 5, 2009 08:36 PM
sawedoffcoupe
Jul 28, 2008 04:01 PM
denracho
Sep 28, 2007 05:02 AM
