What's up with my clutch?
Old Jul 6, 2007 | 08:13 PM
EX-T's Avatar
Default What's up with my clutch?
Today I started up my freshly built D series (Vitara/Eagle) and the car won't move!
Is it possible that I put the clutch disc on backwards, therefore the clutch won't disengage?
When I push the clutch pedal in when the engine's not running, you can hear it going into each gear, but when the engine is running it won't go into any gear. If I push it hard into any gear, the engine starts to bog and will die. If I put it in any gear and try to start it the car moves forward as it is starting.
I've bled the **** out of it and replace the clutch slave cylinder!
for me!
I can put an entirely new engine in a car and it start on the first try, but I can't get it to pull out of the garage under it's own power!
Old Jul 6, 2007 | 08:20 PM
HCivicSi23's Avatar
Default Re: What's up with my clutch? (EX-T)
If it wont disengage, would that not mean that the car would... not stop moving, or release from it's current gear?
Old Jul 6, 2007 | 08:21 PM
EX-T's Avatar
Default Re: What's up with my clutch? (HCivicSi23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCivicSi23 &raquo;</TD></TR><TR><TD CLASS="quote">If it wont disengage, would that not mean that the car would... not stop moving, or release from it's current gear? </TD></TR></TABLE>
huh?
It's like it's in gear all the time unless it's in neutral! If I put it in neutral and let off the clutch it's fine, it idles and everything, but if I push the clutch in and put it in reverse, it's like I'm not pushing the clutch pedal in at all and if I push the clutch pedal in and push it into any gear other than reverse the engine bogs, and dies!!
Old Jul 6, 2007 | 08:24 PM
HCivicSi23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible that I put the clutch disc on backwards, therefore the clutch won't disengage?</TD></TR></TABLE>
That would mean that the clutch itself is not disengaging. Which means its engaged in some gear, so you would be moving to a certain extent? Is it connected to the flywheel, possibly input shaft, correctly?
Old Jul 6, 2007 | 08:27 PM
EX-T's Avatar
The pressure plate is connected to the flywheel correctly b/c there is really only one way to put it on there with the stock bolts. And if the input shaft was not inserted correctly it wouldn't even insert. I'm thinking I put the clutch disc on backwards.
Old Jul 6, 2007 | 08:30 PM
HCivicSi23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking I put the clutch disc on backwards.</TD></TR></TABLE>
Thats possible. Is it a new clutch?
Old Jul 6, 2007 | 08:46 PM
EX-T's Avatar
Thats possible. Is it a new clutch? </TD></TR></TABLE>
It was about 2 months old when I blew my stock D up!
Old Jul 6, 2007 | 08:48 PM
HCivicSi23's Avatar
The only other thing I can think of is the clutch compresor. I know you said you bled it already, but try bleeding it again.
Old Jul 7, 2007 | 04:21 AM
EX-T's Avatar
c'mon, anyone else have any ideas?
Old Jul 7, 2007 | 06:00 PM
EX-T's Avatar
Fixed the problem! The clutch disc was backwards!
Now I have a new problem though!
Old Jul 7, 2007 | 06:01 PM
t0p_sh0tta's Avatar
Now I have a new problem though!</TD></TR></TABLE>
Care to elaborate?
Old Jul 7, 2007 | 06:12 PM
EX-T's Avatar
Default Re: What's up with my clutch? (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">
Care to elaborate?</TD></TR></TABLE>
https://honda-tech.com/zerothread/2035729
Go there!
Old Jul 7, 2007 | 06:17 PM
1992Si's Avatar
Wow, I thought it was impossible to put the disc in backwards.
I guess I was wrong.
Old Jul 7, 2007 | 06:18 PM
EX-T's Avatar
Default Re: What's up with my clutch? (1992Si)
Yep, I did it!
Samwilt
Jul 6, 2011 04:12 AM
kidrolla
Nov 18, 2006 11:24 AM
SonicRacing
Feb 26, 2006 01:54 PM
This One
Mar 21, 2003 05:23 AM
