fitment issue with fmax manifold and wastegate? stud question.. 95 accord
Old Jul 6, 2007 | 03:59 PM
hb_guy's Avatar
Default fitment issue with fmax manifold and wastegate? stud question.. 95 accord
i have an FMAX manifold and a tial style 38mm wastegate for my 95 accord with the stock f22b1 VTEC.. turbo kit is almost ready to be installed just working out last minute details like this one.
the BOLTS i have to secure the wastegate to the manifold actually hit the WG so it will not turn. the WG came with all the hardware necessary so i have allen head bolts with the same thread pitch and i know they will work but i cannot remove the studs.
i tried tightening two bolts together to remove the stud(similar to installing ARP headbolts) but that did not work. those 2 studs are f*cking in there. i am contemplating taking it to my local machine shop..
any other ideas or suggestions?? thanks
Old Jul 6, 2007 | 05:34 PM
hb_guy's Avatar
Default Re: fitment issue with fmax manifold and wastegate? stud question.. 95 accord (hb_guy)
no one?
Old Jul 7, 2007 | 02:02 PM
hb_guy's Avatar
no one??????????????
Old Jul 7, 2007 | 02:37 PM
Turbo-charged's Avatar
your only other option is a stud remover tool which is going to trash the threads. it sounds like if you can't get it off with the 2 nut method, odds are the stud is going to break off and need to be drilled/tapped. most likely whoever installed the studs went overboard with locktite
MalcolmV8
Apr 19, 2012 08:35 AM
boostincoupe
Apr 12, 2006 10:15 PM
Ek00fbp
Oct 13, 2003 11:18 PM
integranator
Sep 9, 2003 08:30 AM
Cramerox
May 23, 2003 11:50 AM
