93k on motor, if i paint my valve cover, do i need to replace my gasket?
Old Jul 6, 2007 | 02:17 PM
pjr710's Avatar
Default 93k on motor, if i paint my valve cover, do i need to replace my gasket?
i want to paint my valve cover, but if i take it off will it be ok to put it on with the original gasket? it will probably be old and it would be wise to put in a new one, but will everythign be ok if i just use the old one?
and also when i install it back on, do i need to put any type of bonding material. Or is it just take it off, then bolt back on
Old Jul 6, 2007 | 02:52 PM
cor0780's Avatar
Default Re: 93k on motor, if i paint my valve cover, do i need to replace my gasket? (pjr710)
I would suggest replacing it since there inexpensive. Just my .02!
Old Jul 6, 2007 | 03:02 PM
HickamHatch's Avatar
depends on how old it is, i reuse my Felpro gaskets without any leaks. Just use gasket sealer on the corners.
Old Jul 6, 2007 | 03:19 PM
pjr710's Avatar
Default Re: 93k on motor, if i paint my valve cover, do i need to replace my gasket? (HickamHatch)
i heard they are like 8 bux at a honda dealership, but then i heard from somone else that they saw one at autozone for 45.
if i replace it this time. can i take the valve cover on and off again without replacing it?
Old Jul 6, 2007 | 03:30 PM
blah blah blah's Avatar
u should
Old Jul 7, 2007 | 07:44 AM
thebinaryman's Avatar
recently sanded and painted mine. i bought the whole "valve cover gasket kit" from an ebay store. i didn't need all the extra little gaskets because i could not get them off the old valve cover without trouble. all you need to replace to be safe is the gasket that is a ring shape that goes around the circumference of the valve cover.
Old Jul 8, 2007 | 07:58 PM
jers99's Avatar
Default Re: (thebinaryman)
Replace it! Its seriously cheap insurance there only a couple dollars and yes ur gonna need to put gasket seal on it that's only a couple dollars
Old Jul 8, 2007 | 08:00 PM
prelude_93vtec's Avatar
Default Re: (jers99)
yea ull need some kind of sealer but theyre really cheap. and a new gasket is prolly a good idea
depo
Mar 23, 2019 09:37 PM
lll
Feb 16, 2007 03:30 PM
crx_88_si
Jul 29, 2004 08:47 AM
type Gendy
10
Sep 6, 2003 10:44 AM
B18C-Hatch
May 19, 2003 02:44 PM
