Did em1's come with front sway bars?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zach1288 »</TD></TR><TR><TD CLASS="quote">I just looked under mine and i dont have a front sway bar!! </TD></TR></TABLE>
Maybe the previous owner removed it for some reason.
What brand do you suggest i get? Also i have decent suspension setup(eibach/KYB gr's) and my tires have been rubing my fender wells could not having the sway bar cause this problem?
Just buy another Si sway bar. If you change to a smaller OEM sway bar, you'll need to change your front LCAs as well (since the Si/CTR has a unique mounting sway bar).
The rubbing of your tires is not caused by your lack of sway bar. It could be from tire width, ride height, wheel offset, or a combination of those factors.
My tires rub my fenders when i make tight turns very fast like in an autocross course. So the sway bar would not help the tire from rubing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zach1288 »</TD></TR><TR><TD CLASS="quote">My tires rub my fenders when i make tight turns very fast like in an autocross course. So the sway bar would not help the tire from rubing?</TD></TR></TABLE>
It might help to some extent, but won't prevent it. Your car will still dip in the front.
Have you got it aligned? It helps... I don't know if you have a firestone but in Oregon, they charge like $130 for life time front&back alignment. I just go there every month and get it aligned and what not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Lifetime alignments FTW.
Worth every penny.</TD></TR></TABLE>
WHA!?!?!??!?! I've never heard of such a thing.. That's awsome... and I pay like $59.99 for alignments once a year or when needed... I have a weird way of always messing up my alignment. Any big companies do this? How do these lifetime things work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony »</TD></TR><TR><TD CLASS="quote">
WHA!?!?!??!?! I've never heard of such a thing.. That's awsome... and I pay like $59.99 for alignments once a year or when needed... I have a weird way of always messing up my alignment. Any big companies do this? How do these lifetime things work?</TD></TR></TABLE>
i know tirekingdom has this plan. you pay a one time fee, and as long as you own the car, they will align it.
I bet your car handles like total crap!!
Eibach and suspension techniques makes front sway bars. You might get lucky and find an OEM sway bar in a junk yard.
http://www.nopionline.com/nopi...Civic
I bet your car handles like total crap!!Eibach and suspension techniques makes front sway bars. You might get lucky and find an OEM sway bar in a junk yard.
http://www.car-part.com
They won't list the front sway bar though.
So, look for front end parts for a '99-'00 Si and then call the business up and ask if they have the front sway bar.
And Firestone has lifetime alignments too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">And Firestone has lifetime alignments too.</TD></TR></TABLE>
Discount Tire rocks too. I have lifetime free alignment with my off-road tires on my truck.
-Shane
-Shane
I ordered the whole OEM assembly but they did not have #13 in stock do i really need that piece? It just looks like a rubber protector? http://www.hondaautomotivepart...82%29
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BJA86 »</TD></TR><TR><TD CLASS="quote">fukn a my 99 si dosnt have the front sway bar either
wow both of you got screwed...Si's have the biggest sway bars out of the 88-00 civics and 90-01 tegs. I would suggest going with a oem one, nothing more nothing less. well actually i doubt theres any body making 26mm+ bars anyways.
</TD></TR></TABLE>wow both of you got screwed...Si's have the biggest sway bars out of the 88-00 civics and 90-01 tegs. I would suggest going with a oem one, nothing more nothing less. well actually i doubt theres any body making 26mm+ bars anyways.
.I ordered the whole OEM assembly but they did not have #13 in stock do i really need that piece? It just looks like a rubber protector? http://www.hondaautomotivepart...82%29
If you make a new thread you might be more likely to get an answer. I don't even know what number thirteen is showing.
Protector, Stabilizer Link
52322-S04-G01
52322-S04-G01
