check engine light
Old Jul 6, 2007 | 10:35 AM
lmattera's Avatar
Default check engine light
How can I reset the check engine light on my 2001 prelude? I have taken to the dealer twice and both times it is the gas cap. ($80) to have the darn light to be turn off by the dealer!
Old Jul 6, 2007 | 11:39 AM
carnot's Avatar
Default Re: check engine light (lmattera)
buy a code reader from your local auto parts store. you can get one for like 40$. It will tell you what code it is throwing and you can reset as well
HybridBB6's Avatar
Take it to autozone and use their scan tool and erase it. Or disconnect your battery for a second
Old Jul 6, 2007 | 11:53 AM
lmattera's Avatar
Default Re: check engine light (carnot)
Thanks for the info, will look for one this weekend
Old Jul 6, 2007 | 11:58 AM
prelude_93vtec's Avatar
did you check your codes? if you have a 4th gen, jump the connector behind the radio and check your code. if the problems solved, reset the ecu or jus disconnect the battery
St3v3
Jul 11, 2007 04:22 AM
oneforce
Mar 10, 2005 12:02 PM
SpeedGyrl
Oct 10, 2002 12:21 PM
mkokwilson
Sep 17, 2002 07:57 PM
mkokwilson
Sep 17, 2002 04:22 PM
