lowered rear wheels rub.
Old Jul 6, 2007 | 09:32 AM
metooblam's Avatar
Default lowered rear wheels rub.
I have a 95 dx hb and i lowered it with the tein s.tech. when i was on steelies they were fine but since i got 16"s now they rub when i do a sharp and fast turn or when i have 1 person in the back seats. i see that some of the bumper is getting scraped and the inside of the qtr panel. what can i do? roll the fenders and cut the inner part of the bumper? thanks.
Old Jul 6, 2007 | 09:37 AM
philosofy1's Avatar
Default Re: lowered rear wheels rub. (metooblam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metooblam &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 dx hb and i lowered it with the tein s.tech. when i was on steelies they were fine but since i got 16"s now they rub when i do a sharp and fast turn or when i have 1 person in the back seats. i see that some of the bumper is getting scraped and the inside of the qtr panel. what can i do? roll the fenders and cut the inner part of the bumper? thanks.</TD></TR></TABLE>
you can do all those things you suggested, or you can do what i did, no backseat passengers. unless, you taking 2 shorty's to you house.
also, what type of tires are on? tires are all made different and some walls sit alittle higher, or wider than others.
pdiggitydogg's Avatar
kick the camber in a little and roll the fenders
Old Jul 6, 2007 | 09:55 AM
g0ni's Avatar
Default Re: (pdiggitydogg)
keep the rear seats folded down, so people think you took them out
Old Jul 6, 2007 | 10:02 AM
BlackoutVTi's Avatar
Default Re: (g0ni)
I have this exact problem too. I just haven't gotten around to doing anything about it because it happens so rarely. I just avoid backseaters until I can get it remedied.
Old Jul 6, 2007 | 12:18 PM
ekhunter's Avatar
you can bend a little piece of metal up in the rear of the quarter panel and the rubbing consideriably stops, for the most part.
Old Jul 6, 2007 | 05:11 PM
metooblam's Avatar
Default Re: lowered rear wheels rub. (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
also, what type of tires are on? tires are all made different and some walls sit alittle higher, or wider than others.</TD></TR></TABLE>
i got falkin azenies 512? the size is 205/45/16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">
kick the camber in a little and roll the fenders </TD></TR></TABLE>
i got alignment done and dont want to mess it up again.
Old Jul 6, 2007 | 08:43 PM
camber doesnt affect tire wear, unless its extreme...
kicking the camber in means you wont have this problem...and its probably the easiest and obvious choice
If you have a rear kit, just mark where the applied settings are, and adjust it.....then you can put it back, if you screw it up badly
Old Jul 8, 2007 | 05:59 PM
metooblam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">camber doesnt affect tire wear, unless its extreme...
If you have a rear kit, just mark where the applied settings are, and adjust it.....then you can put it back, if you screw it up badly</TD></TR></TABLE>
i dont have a rear kit so does anyone know how i can kick the camber in the rear? when i got alignment they didnt do anyting cuz it wasnt adjustible would i do the washer trick?
EJ2GOON
Paint and Body
Jun 15, 2015 05:05 PM
J.nguyen
Jun 29, 2006 02:58 PM
AccordCD5
Mar 15, 2004 07:45 PM
mykejamison
Feb 23, 2004 06:13 AM
