Do '97 Civics have accident fuel cut-off switches?
I've got a friend who has a 97 EX and got in a wreck. We got the car back together, but the fuel pump won't come on, and we're not getting spark to the wires.
I already OHM tested the main relay and it's fine.
We replaced the ENTIRE dizzy assembly too.
Is there an accident cut-off switch or anything else I need to check?
I dont believe that Hondas have them, I know that Ford has them in the trunk area and they are called Inertia swithes. Someone else chime in, but im almost 100% sure that Hondas dont have them. Check Ground wire, for fuel pump, on the cover plate, could have broke it loose, those things are brittle. GL
