trany falling out of gear?
Old Jul 6, 2007 | 12:29 AM
cmasonrun's Avatar
Default trany falling out of gear?
My 5th gear will randomly slip out of 5th gear after im cruising in it for a few min, or a few seconds, its different every time....its a stock b16 trany with 100K on it, but it only started donig this RIGHT after i put the built b20/vtec in....any ideas guys
Old Jul 6, 2007 | 03:28 AM
Mista Bone's Avatar
D Tranny Guru
5th gear sleeve and outer shaft bearing are dieing, common issue with B16 trannys, Honda even has a TSB about it.......
http://www.knology.net/~jediklc/grinds.pdf
Old Jul 6, 2007 | 04:16 AM
ek4_b16a's Avatar
Default Re: (Mista Bone)
same thing happened to my buddies LS tranny...was just low on tranny fluid...fill it up more...check that out first
Old Jul 6, 2007 | 07:39 AM
PhantomLord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">5th gear sleeve and outer shaft bearing are dieing, common issue with B16 trannys, Honda even has a TSB about it.......
http://www.knology.net/~jediklc/grinds.pdf</TD></TR></TABLE>
Old Jul 6, 2007 | 08:58 AM
cmasonrun's Avatar
Default Re: (PhantomLord)
what needs to be done to fix?
Old Jul 6, 2007 | 09:04 AM
Syndacate's Avatar
Default Re: (cmasonrun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmasonrun &raquo;</TD></TR><TR><TD CLASS="quote">what needs to be done to fix?</TD></TR></TABLE>
It's probably cheaper to pull the trans and tear it apart and replace the parts than it is to buy a new one. .
Old Jul 6, 2007 | 09:30 AM
Like Mista Bone said. Replace the shaft bearings. It's cheap and relatively easy to do.
HatchSpeeD
Aug 8, 2007 12:51 PM
White_EK49
Sep 11, 2006 10:11 PM
stefanne3
Jan 30, 2006 01:49 PM
Bense
16
Oct 29, 2004 06:25 AM
crx586
Apr 16, 2003 11:26 PM
