B16a with T3/T4 hybrid turbo, just bought the car and it has stock fuel system, what size injectors
Old Jul 5, 2007 | 11:22 PM
the b man's Avatar
Default B16a with T3/T4 hybrid turbo, just bought the car and it has stock fuel system, what size injectors
curious what size injectors ill need for this engine/turbo setup? Also curious how much boost I can safely run with stock internals and a good tune?
Modified by the b man at 1:10 AM 7/6/2007
Old Jul 5, 2007 | 11:27 PM
almostboostedgsr's Avatar
Default Re: B16a with T3/T4 hybrid turbo, just bought the car and it has stock fuel system, what size inject
rc 440cc injectors
Walbro 255 fuel pump
Adjustible fuel pressure regulator
The wideband setups are bought in kits.
Old Jul 6, 2007 | 12:12 AM
the b man's Avatar
ok... about wideband, so it is more than just an o2 sensor, its a whole kit that must be installed? I can still use the air/fuel gauge I have with a wideband setup right? where can I get such a kit?
Old Jul 6, 2007 | 12:13 AM
the b man's Avatar
oh one more thing, is an adjustable fuel pressure regulator the same thing as an fmu?
Old Jul 6, 2007 | 12:22 AM
Default Re: (the b man)
Alright what you have now is a narrow band 02sensor. Wideband is totally different. You can still use your air/fuel gauge.
A fmu is totally different than a fuel pressure regulator. A fpr makes sure the fuel pressure is kept at what you set it at.
Old Jul 6, 2007 | 04:26 AM
blaze the chemi's Avatar
Default Re: (almostboostedgsr)
check the FAQ at the top of the forum. These will at least give you a start on the basics and what all the terms mean. Try to stay out of boost until you know it's tuned.
Old Aug 13, 2007 | 12:19 AM
the b man's Avatar
ok, thanks for the info, I have one more question though. my vehicle has an n/a motor which was turbo'd, and the fuel system uses a vacuum line running from the intake manifold. Therefore there is positive presssure in the intake manifold now, not negative pressure, meaning no vacuum for the fuel system to use. Is there some sort of change ill need to make to the fuel system itself to have it not need this vacuum, or does it not need it? Is it solely controlled electronically? Just trying to cover all my bases here...
Creator
Feb 7, 2007 12:37 PM
90crxsi88zc
Oct 6, 2005 03:18 PM
Hybridhonda10
Apr 3, 2002 07:39 AM
GSRwBOOST
Jul 19, 2001 11:03 AM
