ls-v w/turbo just finished and hella smoke.
I just finished a ls-v with a turbo and there is a ton of smoke coming out my downpipe and spits oil out downpipe also. Is it more likely that its coming from the turbo or the engine? Any ideas how I can fix it?
did you buy the turbo used? the seals could be out in the turbo causing you to burn all the oil... had a friend with the same problem... never seen a car smoke more...
but if the seals aren't out in the turbo then maybe your oil line...
VTgringo
Jul 1, 2003 06:44 PM
