WEIRD ECU problem...!..??
Old Jul 5, 2007 | 08:54 PM
Sumslapper's Avatar
Year 3030
Default WEIRD ECU problem...!..??
Background: Just dropped a fresh 2000 ls motor into my 94 integra and i had an old ecu that was from a automatic integra but was converted to 5 speed.
For some reason it made my car idle really high and rpms acted like i have a vaccum leak even tho i dont. So i bought another ls ecu that is 5 speed but now i am throwing a CEL for code 16 which is fuel injectors...but now the motor idles fine unlike with my other ecu.
so i put my old ecu back in and pulled the tps sensor to make sure that it throws codes..and it did. so it does throw codes but doesnt throw the same code as the supposedly legit 5 speed?
CLIFFS: Had a bad ecu that caused high idle. switched it to another ecu but now throws a CEL. Pulled the tps sensor on the bad ecu and it throws a CEL but doenst throw a code 16 like the supposed virgin 5 speed ecu. both are ls obd1. im stumped..
Old Jul 5, 2007 | 09:14 PM
ef dino's Avatar
Default Re: WEIRD ECU problem...!..?? (Sumslapper)
i vote stick with ecu number 2.. and make sure the injectors are wired correctly. just my opinion.
and if that doesnt work i guess pull the tps to make sure that ecu is working correctly also. Do you have any friends with an ls. Maybe you could try your ecu on their car to see what it does. idk, thats all i could really think of at 1 am
Old Jul 5, 2007 | 11:43 PM
Sumslapper's Avatar
Year 3030
Default Re: WEIRD ECU problem...!..?? (ef dino)
ya i will doublecheck. I already switched out my injectors for gsr ones and still the same thing on both ecu's i will try an find someone with a ls or possibly a 3rd ecu any other opinions?
Old Jul 6, 2007 | 11:21 AM
Sumslapper's Avatar
Year 3030
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sumslapper &raquo;</TD></TR><TR><TD CLASS="quote"> any other opinions?</TD></TR></TABLE>
rjmteggy
Apr 16, 2015 10:19 PM
gonjaman642
Jul 15, 2010 03:49 PM
averyvm
Engine Management and Tuning
Aug 2, 2008 08:37 PM
erikiksaz1
Jan 17, 2007 10:39 AM
kim_2_da_chee
May 30, 2003 06:18 PM
