HELP, 00 civic with gsr put in ls tranny and having major problem
Old Jul 5, 2007 | 07:27 PM
gsrgirl4u's Avatar
Default HELP, 00 civic with gsr put in ls tranny and having major problem
i have a 00 civic with a 97 gsr swap. i decided to put a ls tranny in it. having major problems with tranny, doesnt want to go into gear, real loose. put a new clutch kit in as well but for the gsr. do i need an different clutch? the ls tranny is"a built tranny" but there are also metal shavings in fluid. please help. when picked up the tranny seen old boot off of shifter and it was ate up. that was the only problem seen. PLEASE HELP!!
Old Jul 5, 2007 | 07:33 PM
HCivicSi23's Avatar
Default Re: HELP, 00 civic with gsr put in ls tranny and having major problem (gsrgirl4u)
If theres metal shavings in the tranny oil, that means gears are grinding. It is possible that one of the synchros is broken or quite possibly a gear itself. Is your shift linkage set up correctly?
Old Jul 5, 2007 | 07:37 PM
gsrgirl4u's Avatar
Default Re: HELP, 00 civic with gsr put in ls tranny and having major problem (HCivicSi23)
i did the gsr swap 2 years ago. when doin the shift linkage it fit fine on the gsr but putting it into the ls is when i started to have problems. we just put the tranny in tonight. wondering if i should get the gsr back? when driving and starting off it feels like im starting off in 3rd gear when in 1st. i have never driven a ls so is it suppose to do that?
Old Jul 5, 2007 | 07:40 PM
hatch96y7's Avatar
i just did a ls tranny on my gsr also
i ate it it feels worse than my d16y7
does ur car lagg really bad now
Old Jul 5, 2007 | 07:42 PM
gsrgirl4u's Avatar
Default Re: HELP, 00 civic with gsr put in ls tranny and having major problem (hatch96y7)
yeah it its nasty. its like it doesnt want to get any gas. but all that is fine. is i just the tranny?
Old Jul 5, 2007 | 07:45 PM
HCivicSi23's Avatar
The limited slip tranny will create a "lag" feeling, but it is a great tranny though. What concerns me is the fact that you are having a very difficult time switching gears and the metal shavings. When you break a syncro and grind gear teeth down, those are the symptoms. With gear teeth however, you will be able to shift gears but the car wont engage the gear/move anywhere. However, the synchros, if broken, will not allow you to engage a gear at all.
Old Jul 5, 2007 | 07:46 PM
gsrgirl4u's Avatar
my brother is the one driving the civic now. he is telling me that he gives it gas and it doesnt want to move. how do i fix it? blow it up? lol jk
Old Jul 5, 2007 | 07:48 PM
HCivicSi23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrgirl4u &raquo;</TD></TR><TR><TD CLASS="quote">my brother is the one driving the civic now. he is telling me that he gives it gas and it doesnt want to move. how do i fix it? blow it up? lol jk</TD></TR></TABLE>
That would deffinatly be a ground up gear. That is the symptom you get when you have ground the gear teeth down. Try taken the tranny apart and replacing the gear, maybe you even have a broken synchro?
gsrgirl4u's Avatar
its goin into gear. see that was the problem with the gsr tranny the shop i took it to messed up the 2nd gear syncro. my brother now has the civic and wanted a ls tranny. he feels that its just not moving, in 1st and feels like its in 3rd when taking off. he told me that the tranny fluid was older than dirt. im lost at what i should do!
Old Jul 5, 2007 | 07:54 PM
HCivicSi23's Avatar
I would honestly take the tranny off the car and look at it myself. You can't always trust what pople tell you about the stuff you buy. It's possible that the syncro is broken.
Old Jul 5, 2007 | 08:42 PM
hatch96y7's Avatar
he saying that it is lagging
not saying it grinds,wont go in gear,pops out she is saying it is lagging.
do u not undersatnd.
why would u advise to take the tranny apart.
if its a synchro it would grind not feel slugish
Old Jul 5, 2007 | 08:48 PM
HCivicSi23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">he saying that it is lagging
if its a synchro it would grind not feel slugish </TD></TR></TABLE>
The gear can grind causing metal shavings in the tranny oil like she described. If it is sluggish, it can be caused by a bad synchro as well. I am not a tranny expert, but it is one of the two.
slowredteg
Jan 12, 2008 09:43 AM
Kamikaze
Jul 12, 2007 12:52 PM
GuateskateVti
Sep 21, 2005 11:11 AM
turbospool
Apr 12, 2003 09:55 PM
94hondaLS
Jan 28, 2003 11:53 PM
