02 RSX type S: seats were removed now SRS light is on, how do i reset it?
Old Jul 5, 2007 | 07:22 PM
bocian's Avatar
Default 02 RSX type S: seats were removed now SRS light is on, how do i reset it?
just as the topic says, i know about the paperclip trick however it says that it will not work if the srs was tripped from the seats being removed. anyone know a way that will get this done without going to the dealer?
thanks in advance!
Old Jul 5, 2007 | 07:24 PM
bocian's Avatar
Default Re: 02 RSX type S: seats were removed now SRS light is on, how do i reset it? (bocian)
Old Jul 5, 2007 | 08:13 PM
JDMk20R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bocian &raquo;</TD></TR><TR><TD CLASS="quote">just as the topic says, i know about the paperclip trick however it says that it will not work if the srs was tripped from the seats being removed. anyone know a way that will get this done without going to the dealer?
thanks in advance! </TD></TR></TABLE>
You can't reset it because the srs plugs are still unplugged. You'll just have to take out the bulb, put tape over it or just roll with it on.
Old Jul 5, 2007 | 08:52 PM
risktypeS's Avatar
Default Re: 02 RSX type S: seats were removed now SRS light is on, how do i reset it? (JDMk20R)
or put 2- 2 ohm resistor into the plugs and fool the srs by closing the loop.
here's how to reset it:
http://forums.clubrsx.com/show...reset
Old Jul 5, 2007 | 10:41 PM
Aco512's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMk20R &raquo;</TD></TR><TR><TD CLASS="quote">
You can't reset it because the srs plugs are still unplugged. You'll just have to take out the bulb, put tape over it or just roll with it on.</TD></TR></TABLE>
lol, you are so wrong lol
but yeah, do the paper clip trick
i did it when i took out my passenger seat to run at the track last year
Old Jul 5, 2007 | 10:57 PM
JDMk20R's Avatar
Default Re: 02 RSX type S: seats were removed now SRS light is on, how do i reset it? (Aco512)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aco512 &raquo;</TD></TR><TR><TD CLASS="quote">
that's wack then lol, because it wouldn't reset when I had my Speeds and Sparco wheel. Wait, are we on the same page? Are we talking about putting them back in and then resetting? If so then yes it will work. But running an aftermarket setup it didn't.
Old Jul 6, 2007 | 12:07 AM
Aco512's Avatar
ah, i gotcha
Old Jul 6, 2007 | 03:13 AM
bocian's Avatar
Default Re: (Aco512)
duh.... thats my fault, i should have clarified, they are back in and the light is on, from what i read, it seems as though the paper clip thing should work
Old Jul 6, 2007 | 04:53 AM
risktypeS's Avatar
It does work if you put 2-2ohm resistors into the srs plugs. It closes the loop for the srs and then you reset it.
Old Jul 10, 2007 | 08:39 PM
flipsyde's Avatar
i did the paperclip trick this past weekend and it worked for me. took me about 15 minutes though, you gotta time everything just right.
Old Jul 12, 2007 | 09:46 AM
Davanca's Avatar
Default Re: (flipsyde)
I don't understand why you guys need to do that. I've taken my seat out plenty of times at the track and when i put it back in the light always went away once the seat was back in. Try and make sure you have everything plugged in properly, and make sure you plug the srs clips in with the car turned off.
Old Jul 14, 2007 | 04:37 PM
Todd00's Avatar
I said I don't want a title!
Default Re: (Davanca)
Timing is the *key* to getting that trick to work correctly. Quoted from the other forum:
"When the light shuts off the first time, pull out the pin right away, you only have a couple of seconds to do it. When it comes back on again, right away put it back in. When it goes off again, pull it out right away, it should flash once, you're done."
I'll add this thread to the FAQ.
Old Jul 23, 2007 | 02:02 PM
vrrodri's Avatar
I tried the paper clip 6 times but each time it flashes twice at the end and comes back on 2 seconds later and stays on....my SRS module is fine. I went through all the steps, everything worked until the last step.
ANY IDEAS
I have a EK hatch
Old Jul 23, 2007 | 05:06 PM
Todd00's Avatar
Default Re: (vrrodri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrrodri &raquo;</TD></TR><TR><TD CLASS="quote">I tried the paper clip 6 times but each time it flashes twice at the end and comes back on 2 seconds later and stays on....my SRS module is fine. I went through all the steps, everything worked until the last step.
ANY IDEAS
I have a EK hatch</TD></TR></TABLE>
An EK hatch might be/probably is a different procedure. Try asking in that forum.
TeamRedlineEM2
Honda Civic (2001 - 2005)
Sep 15, 2007 06:39 PM
seer
Sep 12, 2006 03:42 PM
b16 matt
Sep 8, 2005 04:38 PM
EVOrence
Jan 16, 2005 09:49 PM
wanganator
Oct 26, 2004 03:17 PM
