downshifting kills trans????!
so is downshifting a bad idea? originally i heard it's better for the car and doesn't hurt it at all but now i've been hearin it blows your transmission...so should i stop the downshifting and just go to neutral and brake? cus it's been kinda fun
It's not bad for the tranny if you do it right, in the type s your not supposed to downshift from 4th to 2nd from what i heard. I do it anyway cause i dont really care.
blip the throttle in neutral without the clutch pedal depressed to save the synchros
clutch in, move to neutral
clutch out, rev engine while in neutral
clutch in, move shifter into gear
clutch out to engage gear.
repeat per gear and your trans will last a lot longer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tadehi »</TD></TR><TR><TD CLASS="quote">You downshift to save your brakes and gain fuel economy. However the key is to go down through every gear. I.e. 6-5-4-3-2, I never put mine into 1st ever!</TD></TR></TABLE>
please explain how it betters fuel economy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy »</TD></TR><TR><TD CLASS="quote">
please explain how it betters fuel economy.</TD></TR></TABLE>
if you don't blip the throttle the injectors are cut off because the wheels/trans is keeping the engine spinning.
you'll save gas, but your clutch, synchros will hate it.
not worth it.
not worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phthalo »</TD></TR><TR><TD CLASS="quote">i use it to slow down my car...saves the live of my rotors and brake pads
this is the worst reason to do it ever.
1. it makes your engine wear out faster
2. it makes your synchros wear out faster
3. it makes your clutch and pressure plate wear out faster
4. it wastes gas
5. pads are maybe 50 a set and will last you at least a year
6. rotors are cheap
rotors + pads cost way less than drivetrain rebuilds.
rotors + pads are way easier to replace/change than drivetrain components.
</TD></TR></TABLE>this is the worst reason to do it ever.
4. it wastes gas
6. rotors are cheap
i've had an old bmw 316i 1984 and downshifted numerous times.. had no wear and tear except the usual ageing. Only wear and tear you're going to get is from old age unless you beat the **** out of it.
If you downshifted why would it waste gas?
if that's the case then automatics eat ASSLOADS OF GAS.
in the 316i i had the stock clutch in it from 1984 and original synchros
so i'd like to know where you got your info from.
also you say downshifting also gives wear and tear on pressure plate and clutch.. well it's no different then shifting period.. so if that's the case then shifting just ruins the whole tranny
this downshifting has been dragged out to long..
Just downshift normal without over doing it and you'll be fine. Downshifting is no different then regularly shifting. THE END!
well if that's the case then automatics eat a lot of gas. Gas is only given by the amount you're pushing the throttle in not at which rpm you're at. Why do you think they call it a "gas peddle"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS »</TD></TR><TR><TD CLASS="quote">i've had an old bmw 316i 1984 and downshifted numerous times.. had no wear and tear except the usual ageing. Only wear and tear you're going to get is from old age unless you beat the **** out of it.
Just downshift normal without over doing it and you'll be fine. Downshifting is no different then regularly shifting. THE END!</TD></TR></TABLE>
lol
you have three options when downshifting.
1. let the transmission speed up your engine for you (stress on drivetrain)
2. spin the engine to the right speed (wastes gas, still puts stress on synchros unless you double clutch)
3. spin the engine to the equivalent speed while double clutching (wastes gas, no extra load on trans)
either way it's not worth it.
If anyone says "I do it because it's fun" or "I do it so i can practice heel toe downshifting so that when I road race I'm ready for it" or "I do it to impress chicks"
Those reasons would make sense.
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS »</TD></TR><TR><TD CLASS="quote">well if that's the case then automatics eat a lot of gas. Gas is only given by the amount you're pushing the throttle in not at which rpm you're at. Why do you think they call it a "gas peddle"?
If my engine is not getting gas and firing while downshifting, why is the exhaust so loud? And automatics do eat more gas than standard.
</TD></TR></TABLE>If my engine is not getting gas and firing while downshifting, why is the exhaust so loud? And automatics do eat more gas than standard.
1)Stress is on drivetrain regardless downshift, upshift
2) whether you downshift or normaly shift you're still putting stress on your synchros
3) there are to many factors on "wasting gas"
4) let me recorrect myself, the "gas peddle" only depicts how much air is given in the ratio of 14.7:1 gas therefore downshifting into higher gear and not giving it "gas" you're really not "eating" gas up. If you're constantly in the high rpms to keep it up there then yes you are eating gas.
now if you downshift for the "i'm kool" type then you're just retarded.
Modified by risktypeS at 5:40 PM 7/6/2007
automatics eat more gas then manuals because the TB is always open and your TB is connected to your "gas peddal". I never said they didn't eat more gas then manuals i just said if downshifting eats more gas then automatics eat a lot of gas cuz they downshift a lot. Automatics downshift reasonabley and that's not the reason why they eat gas.
and when i'm talking about downshifting i'm not talking about downshifting to get your rpms back up i'm talking just downshifting to slow your car down not giving it "gas"
Your exhaust is loud because your at higher rpms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">
not worth it.</TD></TR></TABLE>
Close, when you let the engine brake for you it stops the spaying of fuel into the combustion chamber, thus creating a vacuum and thus slowing the car down. If I drove a Type-S or an Si I wouldn't drive like that just so that I save my synchros. But then again I drive a 01 4 door sedan.
lol
Those reasons would make sense.</TD></TR></TABLE>
I disagree because unless you don't take car of your car with proper maintenance there is no reason for it to break down. Decelerating creates the exact same forces as accelerating. If you do it right there should be no added stress to either the transmission or the engine.
lol
