Wandering with JDM 16's, but not with 15's, same tires
why is my R wandering with JDM 16 inch wheels with FAlken Azinis sport 215/45 R16's, but it's perfect with the oem 15 inch wheels with Falken Azinis sports in 205/50 R15's
Tires on the 15's are old, bald and have uneven wear from being on my turbo'd 87 Teg...I had these mounted on the OEM ITR 15's
Tires on the 16's have only a few thousand miles, perfect wear and plenty of tread.
I feel much more confident on the 15's as i can tell when they are at their limit, but the 16's it will just all the sudden loose grip mid turn. Weels are perfectly ballanced as well.
i did the same swap, same tires, jsut 16inch K1s. i had the same problem. Went for an aligment and all better. even though the aligment was good with the 15s, after going to the 16s it needed done.
^ 2x... You just have less side wall, and the road is probabl slightly slanted thus wandering.
If it's really bad, it could be under inflated tire on one side, or slightly out of wack alignment
I think there is something up with this Model Tire.. I have them on my 15's with 1500miles on them, they cut loose all the timeit seems! I miss my old Azenis's
Rotate your tires front to back and see if problem goes away.
Check tire pressure.
Is your car aligned? Some tires will react differently as opposed to others.
raverx3m
Northwest (Sales)
Dec 27, 2011 06:02 PM
andymacEK9
15
May 17, 2010 07:48 PM
Spunkster
Jul 6, 2007 09:04 AM
mawreeo
Nov 27, 2005 02:36 PM
