92' Engine Heating Problem
Old Jul 5, 2007 | 02:07 PM
anduhy's Avatar
Default 92' Engine Heating Problem
well my engine overheat and i dont no what may be causing it too. on the gauge it's like always on H. so i dont no whats the problem. the gauge is not broken. any suggestion.?
Old Jul 13, 2007 | 12:29 AM
HondaPrelude92's Avatar
Default Re: 92' Engine Heating Problem (anduhy)
did u figure out what was wrong with it? im having the same problem with my prelude..
Old Jul 13, 2007 | 12:34 AM
MasterShake's Avatar
1. is it full of 50/50 fluid?
2. have you tried bleeding the system?
3. check for leaks
4. get it pressure tested
5. test the cap
6. test the thermostat
7. when was the last time the water pump was changed?
thats all i can think of right now
Old Jul 13, 2007 | 12:35 AM
ejallday's Avatar
Check your coolant lines. I bought me 96 cause these people thought the engine was blown and it was a heater hose. Check your oil is there water in it?
Donohu151
Jan 10, 2014 06:14 AM
UNDER PRESSURE
May 21, 2011 12:19 PM
hondateg10
May 1, 2008 09:34 AM
honda4le
Oct 21, 2007 12:57 PM
TheNanashi
Mar 30, 2003 11:13 AM
