will these lines work for turbo coolant?
Bolt on the head right under the valve cover....is that coolant(in or out)??
Bolt on top of thermostat, is that coolant in or out?
I need to run coolant line to my gt30r, and im trying to find the cleanest places to run the lines. I don't want to have to tap into rubber, i want to use an fittings. thanks!
no, the bottom picture is your bleeder valve for your coolant system. tie the lines into the line going to the IAC or FIAC just make them braided.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91crxturbo »</TD></TR><TR><TD CLASS="quote">Bolt on the head right under the valve cover....is that coolant(in or out)??</TD></TR></TABLE>
Def do not use this. That bolt is there to hook up a gauge and check vtec oil pressure.
If you would like, I can send you one of the installation sheets we include with our water line kits. It shows in pretty good detail where we suggest to connect your water lines. Basically, we connecting them in-line with the IAC lines. (The guide was written for D series installs, but it shouldn't be too hard to map the connections to the B.)
Just hit us up with an email sales@tunertoys.com, and we'll send a reply with the instructions as an attachment. They'll be in MSWord format.
Thanks from Craig
Thanks from Craig
91crxturbo
Aug 22, 2007 03:28 AM
