DID I BLOW MY ENGINE, or just a seal or gasket? what's wrong with my car?
Old Jul 5, 2007 | 12:11 PM
SIRIUS VTEC's Avatar
Default DID I BLOW MY ENGINE, or just a seal or gasket? what's wrong with my car?
Ok im on the 110 freeway towards pasadena when my motor starts smoking my pedal loosens up and smoke starts coming through my vent and into the trunk. i park the car in highland park. everytime i start the car i can hear knocking in the hed im assuming the pistons are hitting the head all the oil is drained. do u think it's the valve cover gasket or the motor is blown? the car still starts horribly though. so can i just replace the gasket and buy oil.
Old Jul 5, 2007 | 12:25 PM
sageuvagony's Avatar
Default Re: DID I BLOW MY ENGINE, or just a seal or gasket? what's wrong with my car? (SIRIUS VTEC)
motor has to be blown.. do you see oil spillage anywhere? If so? Near the head? or none at all? You probbaly cracked your block, threw a bearing, engine is bad especially since you say oil is drained.. Valve cover gasket would not have caused this. And if it WAS the valve cover gasket, means oil all leaked out (which most likely didn't happen) and you ran your engine dry of oil.. and threw a bearing which in turn threw everything else out... The majority of the oil doesn't sit in the head, it sits in the pan/block. Did you overheat the car at all?
Old Jul 5, 2007 | 12:30 PM
speedooo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS VTEC &raquo;</TD></TR><TR><TD CLASS="quote">--------------------------------------------------------------------------------
Ok im on the 110 freeway towards pasadena when my motor starts smoking my pedal loosens up and smoke starts coming through my vent and into the trunk. i park the car in highland park. everytime i start the car i can hear knocking in the hed im assuming the pistons are hitting the head all the oil is drained. do u think it's the valve cover gasket or the motor is blown? the car still starts horribly though. so can i just replace the gasket and buy oil.</TD></TR></TABLE>
Im guessing you ran your car out of oil and you spun a bearing. Or if you say the noise is coming from the head, maybe you ate a valve or something? If its just a stock single cam, replace the motor
Old Jul 6, 2007 | 11:13 AM
yea i see the huge hole in my block. so now i need a new motor. sucks. how much do stock d16y8's run for? plus install?
Old Jul 6, 2007 | 11:17 AM
B16b-EJ8's Avatar
I smell a troll...but if not, you can find them on here between 4-800 bucks, install should be cheap since it is PnP
MeanGreenMachine's Avatar
Default Re: (SIRIUS VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS VTEC &raquo;</TD></TR><TR><TD CLASS="quote">yea i see the huge hole in my block. so now i need a new motor. sucks. how much do stock d16y8's run for? plus install?</TD></TR></TABLE>
ouch!
y8's arent too much, youll just have to do some looking around, im sure it couldnt be too hard to find one as alot of ppl are doing b h and k series swaps so the d series motors should be almost everywhere....
Old Jul 6, 2007 | 11:24 AM
since my engine is blown what parts are interchangable if i get a new block?
what parts from my blown d16y8 can i use and not use.
i found alot of d16 heads on here but im trial only cuz i lost my other account password. im def not a noob. lemme know thanks.
Old Jul 6, 2007 | 11:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS VTEC &raquo;</TD></TR><TR><TD CLASS="quote">since my engine is blown what parts are interchangable if i get a new block?
i found alot of d16 heads on here but im trial only cuz i lost my other account password. im def not a noob. lemme know thanks.</TD></TR></TABLE>
whatever is salvageable. if the block has a hole in it then its pretty much trashed, you might be able to use the head depending on if its still good or not. maybe use the intake manifold, throttle body, fuel rail, injectors, dizzy, transmission,engine harness etc...
Old Jul 6, 2007 | 11:29 AM
Default Re: (MeanGreenMachine)
oh yea hey can someone help me out i found a d16y8 used $100 shipped on marketplace for sale....here's the link can someone tell that guy to email me...i have 3 links can someone please inform these guys imma buy one asap depending on who emails me first. in dying need of my motor back.
$150
https://honda-tech.com/zerothread?id=1999886
$100
https://honda-tech.com/zerothread?id=2034264
$170
https://honda-tech.com/zerothread?id=1985884
thanks guys i do appreaciate the help. this is my first engine problem and Got damn it's a huge one.
MY EMAIL ADRESS IS..
ABSOLTUJAY86@AOL.COM
I REPEAT
ABSOLUTJAY86@AOL.COM
Modified by SIRIUS VTEC at 12:43 PM 7/6/2007
Old Jul 6, 2007 | 11:38 AM
hmtcrxsir's Avatar
oh so that was you that was parked on the freeway huh? i should have stopped and helped.
Old Jul 6, 2007 | 11:40 AM
the sellers listed in those for sale threads have been PM'ED by me and referred back to this thread..........i also provided them with your email addy
Old Jul 6, 2007 | 11:43 AM
guys i thank u so much i appreciate all the help and support. u guys are great..
hey did u really see me on the freeway or are u just pullin my nuts? i was headed to a firework show at the rose bowl.
Old Jul 6, 2007 | 11:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS VTEC &raquo;</TD></TR><TR><TD CLASS="quote">guys i thank u so much i appreciate all the help and support. u guys are great..
hey did u really see me on the freeway or are u just pullin my nuts? i was headed to a firework show at the rose bowl.</TD></TR></TABLE>
hey sirius, u should have a email. one of the guys (ridin98civic) selling the stuff in the links u posted just PM'ED me back saying he emailed u
Old Jul 6, 2007 | 11:51 AM
ridin98civic's Avatar
Default Re: (hmtcrxsir)
emailed you
Old Jul 6, 2007 | 12:21 PM
Frozen E's Avatar
H-T White Ops
Is this SIRIUS? As in the green couch guy?
Old Jul 6, 2007 | 01:32 PM
I swore he said he had a hole in the block.. Maybe I'm blind but I swear I don't see a block in any of those sales.. Just heads...
Old Jul 7, 2007 | 06:53 AM
if my block is blown. wouldn't i need an entire motor or just the short block?
Old Jul 7, 2007 | 01:06 PM
Frozen E's Avatar
H-T White Ops
If your head is still good, just get a new bottom end, have that and your head resurfaced, new head gasket and away you go.
Old Jul 10, 2007 | 02:01 PM
hmtcrxsir's Avatar
Default Re: (IslandSi)
yeah i think i saw you over by the side of the freeway
Old Jul 10, 2007 | 04:35 PM
5_Lug_B's Avatar
* B A N N E D *
Ouch
gooblinn258
Feb 12, 2014 04:51 AM
Adankid
14
Sep 7, 2008 06:14 AM
90CivicDaily
12
May 4, 2008 10:12 AM
EkFG
Mar 15, 2008 07:47 PM
RallySportCivic
Dec 23, 2002 11:17 PM
