building internals
Old Jul 5, 2007 | 11:08 AM
egbaby's Avatar
Default building internals
so i was about to boost my car but i was told that its easy to blow an h22 if its boosted and the internals are not built. I'm kinda new to this car thing. Can people tell me what i should upgrade to build my internals? and how much will it approx. cost and will it add horses as well?
Old Jul 5, 2007 | 11:20 AM
t0p_sh0tta's Avatar
Default Re: building internals (egbaby)
How much power are you looking to make?
Old Jul 5, 2007 | 11:52 AM
egbaby's Avatar
Default Re: building internals (t0p_sh0tta)
the h22 is on my 1993 civic hatch.. And i was told that h22 is bout 200 stock.. i'm eventually going to go turbo with it... i've brought it to the tracks and the best i pulled was a 13.720. I wanna pull 13's or under....
Old Jul 5, 2007 | 12:14 PM
t0p_sh0tta's Avatar
If all you want to do is break the 13's, then just get some slicks and a nitrous kit. You can EASILY get into the 12's with a basic turbo kit on your stock motor.
Old Jul 5, 2007 | 08:32 PM
egbaby's Avatar
do you think i should build my internals before i put the turbo on?? because like i said people say its easy to blow the engine if its not built right or upgraded
Old Jul 6, 2007 | 04:04 AM
t0p_sh0tta's Avatar
Save whatever you're going to waste on internals and use it towards tuning. Your goals are easily achievable with a minimalist budget.
You should be able to get below 13 with your current setup if you put some time and effort into it.
Old Jul 6, 2007 | 04:09 AM
mikeycivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egbaby &raquo;</TD></TR><TR><TD CLASS="quote">people say its easy to blow the engine if its not built right or upgraded</TD></TR></TABLE>
^^^these people dont know what they are talking about..do compression test on your motor, if your good across the cyl. then boost it and get good tune and you will be A O K
Old Jul 6, 2007 | 04:48 AM
JKov240's Avatar
Default Re: building internals (mikeycivic)
If you do decide to build your H22, make sure you're getting the right internals for your motor.
The H22 has a special sleeve/coating on the cylinder walls...so you either get pistons that are made for that or you get new sleeves...or both
Old Jul 6, 2007 | 01:17 PM
egbaby's Avatar
Default Re: building internals (JKov240)
i'll probably go get the compression test first... For the pistons and sleeves/coating do you know how much will those part approx. cost?
Old Jul 6, 2007 | 02:01 PM
JKov240's Avatar
No idea.
All I know is that some guy brought his Prelude to our shop with a "built motor" with regular ol' forged pistons and rods. No problems yet, but eventually the motor seizes up and won't move.
Drifter6508
Appearance Build Threads
Nov 2, 2009 03:12 PM
HondaVTEC1993
Dec 6, 2005 05:16 PM
2.2ForU
Dec 10, 2004 11:43 AM
Lude-Conduct
Feb 15, 2004 04:34 PM
Timmayeg
Aug 13, 2002 12:25 AM
