Removing Manual Window Regulator 92 CX hatch...?
Old Jul 5, 2007 | 10:40 AM
standbackimapro's Avatar
Default Removing Manual Window Regulator 92 CX hatch...?
One of the arms are bent on my 92 cx hatch, How can i remove the regulator?
Anyone have pictures or a DIY?
Would a Haynes or chiltons manual have somthing on removing it?
Old Jul 5, 2007 | 11:39 AM
instructor74's Avatar
Default Re: Removing Manual Window Regulator 92 CX hatch...? (standbackimapro)
You need to remove the window crank ( has a small clip holding it in place), inner door handle trim ( screw behind handle). and arm rest cup ( screw in bottom) pull off the inner door. ( should see plastic vapor barrier covering door (peel away from door). Next install the window crank minus its clip move window up and down to gain access to the 2 10mm bolts holding the window to the regulator. Slide window out through the top. Now remove the 3 bolts around the crank 10mm I think. there is 1 or 2 more that you need to remove. Once all bolts are out fish the regulator out and install the new one is the rev of removal
revn9k
May 26, 2022 03:33 AM
codrulz
May 29, 2010 06:37 AM
standbackimapro
Jun 18, 2007 10:08 AM
george34
Jul 28, 2005 08:49 PM
AnclyT
Jul 18, 2005 12:01 AM
