Stock map sensor is good for 14 psi?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks »</TD></TR><TR><TD CLASS="quote">i bar is almost 14 psi, so i doubt that 1.75 will work, but I have heard up to 11</TD></TR></TABLE>if a bar is close 14psi an are stock one is 1.75..why wouldnt hold 14psi?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">1.75bar, meaning 11.2ish psi</TD></TR></TABLE>
read this
he is saying 1.75 bar is 11.2 psi
read this
1.75 bar =
atmosphere (so take 1 bar away) + .75 bar (11.02) = 1.75 bar
you have to take atmospheric away.
1.75 bar =
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">1 bar is 14.5psi if anyone cares
so there would be the .2 i am missing.
</TD></TR></TABLE>so there would be the .2 i am missing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spets »</TD></TR><TR><TD CLASS="quote">1 bar is 14.7, not 14.5</TD></TR></TABLE>
no, that is not true. one ATM is 14.7
Its a 1.75bar sensor that gives you the full 1.75bar range and then some. Not many sensors that play a key role will have a range less than what they are rated for.
BTW if it matters, 1.75bar OBD0 MAP's can only read about 10.8psi due to the diaphram being a diff design, OBD1+ MAP's read over 11psi.
one problem with pushing a MAP sensor to the limit is you loose the overboost feature. if you are boosting a stock map sensor anywhere over 10psi, you will not have a reliable boost cut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg »</TD></TR><TR><TD CLASS="quote">one problem with pushing a MAP sensor to the limit is you loose the overboost feature. if you are boosting a stock map sensor anywhere over 10psi, you will not have a reliable boost cut.</TD></TR></TABLE>
x2 and you dont want to do that... the boost cut will keep your motor alive if something goes wrong, like a wastegate line coming off or whatnot.
