Eagle Rods wrong or not
Old Jul 5, 2007 | 07:10 AM
vtec dub's Avatar
Default Eagle Rods wrong or not
Hi guys Iam new to this site,but i have some questions about a set of eagle rods that i have purchased.
When I put my ACL bearing into the rod, I have a offset on the top half +-1mm from the center and on the bottom half also +- 1mm but to the other side. I have spoken to a couple of guys and some said it is OK and others strongly disaggreed. Can the notches be in the wrong position or is this a manufacturing fault?????
The thing is when I put these rods on my crank and I only hand tighten the bolts of the rod cap. The rod does not even want to turn. Guys PLSE I need some serious answers about this problem that I am having.
Thanks in advance.
Old Jul 5, 2007 | 08:54 AM
4g hatch's Avatar
Default Re: Eagle Rods wrong or not (vtec dub)
pics
Old Jul 5, 2007 | 09:05 AM
Golden Eagle's Avatar
what motor do you have? whats the part numbers on the bearings and rods you have?
Old Jul 5, 2007 | 09:49 AM
DonF's Avatar
Default Re: Eagle Rods wrong or not (Golden Eagle)
Sounds like GSR or D16 bearings in a LS rod.
vtec dub's Avatar
B20b block & crank, b16a head, eagle rods, Acl bearings 1T1957-STD, 5M1959-STD, 4B1946-STD.
My motor ran fine and I made 138kw on the wheels and all was standard, But I am going BIG now.
Old Jul 5, 2007 | 10:12 AM
DonF's Avatar
4b 1946 is the correct number, look at the back side of the bearing and make sure that is the number, not 1925 (GSR)
Old Jul 5, 2007 | 10:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec dub &raquo;</TD></TR><TR><TD CLASS="quote">B20b block & crank, b16a head, eagle rods, Acl bearings 1T1957-STD, 5M1959-STD, 4B1946-STD.
My motor ran fine and I made 138kw on the wheels and all was standard, But I am going BIG now.</TD></TR></TABLE>
i know there are a bunch of eagle rods out there right now that were ls rods set up to use b18c bearings sounds like that's what you have. if you post pics i could tell you for sure or if you can get some b18c bearings try them if they fit that's what you have
Old Jul 5, 2007 | 11:05 AM
vtec dub's Avatar
https://honda-tech.com/zerothread/2030800
Sorry guys but I have allready sent the package back to the vendor.
But if u look at the link at the top. You will see the similar effect on the offset, but just alittle more offset. (dont look at the bearing damage).
Professor X
Aug 10, 2012 11:22 AM
Vtec92Civic
Sep 1, 2005 10:20 AM
minivan81
Apr 5, 2004 04:38 AM
Killer_B
Jun 25, 2003 11:06 AM
