For Sales. 03 - 05 EVO 8 Engine Management Turbo XS UTEC.
Like The Title Said.
I'm Selling A 03 - 05 Evo 8 Engine Management Turbo Xs Utec. Selling It For A Friend.
Regulator Price Is $1,049.00. My Friend Is Asking For $900.
Product Description
-Plug-&-Play installation with OEM connectors for EVO VIII
-No cutting, splicing or additional sensors required
-20 minute, do-it-yourself installation
-End-user programmable via PC or PDA with -HyperTerminal and serial cable
-Fine tune the maps for your exact setup
-Pre-programmed base maps get you started quickly and safely
-Base maps for our Staged upgrade packages, dyno proven and road tested.
-Don’t waste hours tuning just to get your car to idle and cruise decently
-Maps can be e-mailed or simply downloaded then uploaded
-Four (5) maps plus “stock mode� selectable with a flick of the switch
-Create custom maps for street gas, race gas, nitrous, or whatever
-No need to lug around a laptop just to switch between your programs
-Optional remote dash mounted switch available
Fuel, ignition timing, and boost are programmable in 250rpm increments up to 9000rpm over 10 load sites
-Complete ignition timing control
-No need to worry about the factory ECU pulling timing anymore
-Be as aggressive or conservative as you want or just let the factory ECU determine timing at any point in the map
-Fuel control
-Controlled via MAF sensor signal offset
-Tune stock and larger than stock injectors
-Load reference
-MAP (manifold pressure)
-Closed loop boost control programmable via Throttle Position and RPM
-No more re-adjusting the boost controller due to changes in temperature or altitude
-Keeps boost low while in closed loop fuel mode for reliability
-Knock control
-Automatically retards timing when the knock is detected safeguarding against engine damage
-Adjustable knock threshold, timing correction, and duration
-On board data logging
-Provides valuable information to assist you in tuning
-Built in programmable solenoid controller
-Control nitrous, water injection, intercooler water -spray or any other solenoid device
So If Your Interested In It, Please Feel Free To PM/AIM Me. Thanks
AIM = JDM KID 510
Thanks.
Product Description
-Fuel control
-Load reference
-Knock control
AIM = JDM KID 510
Thanks.
HatchEh2
15
May 18, 2006 09:26 AM
intekragsr
Jun 11, 2003 08:41 PM
