Undercoating coming off.....
O.k. searched archives and found this thread.....
https://honda-tech.com/zerothread?id=425704
anybody else having this problem... esp. those w/ 97-98....being that they are 10 yrs old....my wheel wells are white on the inside now, not black.... it looks shitty, and i want to help protect the car from corrosion and or rust...
anyways, i went to duplicolors website and they list a few different undercoatings....
http://duplicolor.com/products/undercoating.html
which one should i buy? which did you buy for those that have experienced this problem?....
Mine did the same thing. I just went to a parts house and bought the cheapest stuff i could find and sprayed it on. It seems to have lasted a while.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R »</TD></TR><TR><TD CLASS="quote">Rhino Lining FTW. </TD></TR></TABLE>
yeah, someone else mentioned this to me....
i wonder how inconvenient this would be to get done...
i.e. removing the wheels and taping everything up while at the place that does these coatings....
i would think that it would be more difficult to apply to the wheel wells of a car than a flat bottom or side of a pickup bed.....
Did you check to see if Honda had a part # for a can of this or something?
I personally wouldn't do anything as semi-permanent as Rhino-lining.
I've re-sprayed the wheel wells on both my ITR and Civic. All I used was a cheap can of rubberized undercoating and put on two thick coats.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">I've re-sprayed the wheel wells on both my ITR and Civic. All I used was a cheap can of rubberized undercoating and put on two thick coats.</TD></TR></TABLE>
do you remember which one you used?
there are four different ones in the link i provided.....
I used a different brand, but any of the ones listed will work fine. I'd stay away from the asphalt undercoating, but that's more of a personal preference than anything.
Finally got around to respraying the undercoating in the wheel wells.....It has been 100 degrees w/ 100% humidity for weeks.....
Very nice day at the beach today....
so...I pressure washed the remaining undercoating off.....cleaned the surface w/ brake cleaner..... and then sprayed on the undercoating......
before
after
before
after
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTZMatt »</TD></TR><TR><TD CLASS="quote">It looks good. What type of undercoating did you use?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL »</TD></TR><TR><TD CLASS="quote">Looks good Cameron, interested in what you used.</TD></TR></TABLE>
Less than $4 a can at Advance auto.....
1 can did both rear wheel wells.....
I used the same stuff as you and worked great. what I also did to prevent any honda rot on the rear quarters is pull away rubber seal on wheel well edge and spray heavily on inner edge and re-installed rubber while wet. when it dried it kinda sealed the rubbers and the inner edge as one to prevent any dirt or sand build up.
