aftermarket pistons with stock rods?
Old Jul 4, 2007 | 04:52 PM
crxfreak1117's Avatar
Default aftermarket pistons with stock rods?
can i just buy aftermarket pistons and use the stock rods would that hurt anthing? gonna be for turbo on my b16
Old Jul 4, 2007 | 05:34 PM
Jared's Avatar
why would you do that when you can get some eagles for 300 while the engine is already apart?
Old Jul 4, 2007 | 05:37 PM
Tinus Tussengas's Avatar
Default Re: (Jared)
x2
And you can use the best pistons ever made, but when you make enough torque, your rods still wont hold..
LoSt is BlaCk's Avatar
Default Re: (Jared)
if your on a budget sometimes you gotta work with what you got...you can definately use the stock rods with the forged pistons...the first motor i built was a simple, forged piston, shot peen'd rod set up...it did what i needed it to do...the machine shop can even make your stock rods and forged pistons into a floating pin set up...
good luck and happy boosting
Old Jul 4, 2007 | 05:41 PM
Default Re: (LoSt is BlaCk)
yes im on a budget what kinda money am i lookin at to do rods and pistons what else would i needl like head gasket arp head studs?
Old Jul 4, 2007 | 05:46 PM
Default Re: (crxfreak1117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfreak1117 &raquo;</TD></TR><TR><TD CLASS="quote">yes im on a budget what kinda money am i lookin at to do rods and pistons what else would i needl like head gasket arp head studs? </TD></TR></TABLE>
if you decided to do rods you can hit up the h-t sponsor section of forced induction classifieds...you can find rods for about $300 as stated above...you could push the motor a lot more if you waited and bought a set of rods...i would definately get arp head studs and a good head gasket...honestly if you take your time and build it strong the first time you will have less worries in the motor...
Old Jul 5, 2007 | 08:37 AM
my plans is to get it runnin for now with the turbo becuase its my daily driver but im gonna build one on the side
Old Jul 5, 2007 | 10:34 AM
if your building a motor on the side you should totally take your time and do both rods and pistons...but on second thought, it also depends on your HP/TQ goals...
Old Jul 5, 2007 | 10:42 AM
tony413's Avatar
use the stock rods get them cryotreated and get ARP rod bolts and your set you wont need to upgrade untill MAYBE over 400hp
the cryotreating will cost like $30-$50 per rod tho i believe and then you gotta but the arp rod bolts so maybe you should just get some eagles and call it a day
Old Jul 5, 2007 | 12:02 PM
raceACCORDingly's Avatar
50 per rod.. might as well fork out another hundo and get eagles
Old Jul 5, 2007 | 12:23 PM
TunerToys's Avatar
The work and effort you'll put into making aftermarket pistons work with factory rods, when compared to the power handling capability of the end result, is just not worth it. Buy some Eagles, or Scats, and enjoy the peace of mind that those components don't often fail under big loads.
Craig
Old Jul 5, 2007 | 03:03 PM
Default Re: (TunerToys)
but im not goin to be boostin the hell out of it im just gonna run like 7psi so idk
Old Jul 5, 2007 | 03:35 PM
Adriano's Avatar
I have seen plenty of people with stock b20/b18 bottem end make 400-420whp by only upgrading rods bolt to ARP bolt. A friend of mine is currently making 440 with a b20, arp rod bolts, double h/g and arp headstuds. I would just do that or put in both aftermarket piston/rods.
Adriano
Old Jul 5, 2007 | 04:05 PM
MeanGreenMachine's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfreak1117 &raquo;</TD></TR><TR><TD CLASS="quote">can i just buy aftermarket pistons and use the stock rods would that hurt anthing? gonna be for turbo on my b16</TD></TR></TABLE>
word.
u can work with whta you got, but at least be patient and upgrade the rods while your at it.
a buddy of mine had some cp pistons on ls rods in his 94 ls motor. rod snapped while he was on the hwy.........i told him to upgrade his rods while the motor was apart, but nope,........he didnt....
Old Jul 5, 2007 | 04:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfreak1117 &raquo;</TD></TR><TR><TD CLASS="quote">but im not goin to be boostin the hell out of it im just gonna run like 7psi so idk</TD></TR></TABLE>
if you seriously think you will stay at 7psi you don't even need to spend money on pistons..just run a stock motor...too many people over build...
Old Jul 5, 2007 | 07:04 PM
morgan@synapse motorsport's Avatar
you have to machine the rods to work with the forged pistons.
if you are doing the build right you are already spending about 1500 dollars in parts, between getting a new head gasket, timing belt, water pump, oil pump, bearings, machining the block, and crank if necessary, new pistons, head studs...the rods should only make sense.
work with what you have, but keep in mind it cost more to build it wrong twice than right once.
Old Jul 5, 2007 | 10:03 PM
tony413's Avatar
Default Re: (Adriano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano &raquo;</TD></TR><TR><TD CLASS="quote">I have seen plenty of people with stock b20/b18 bottem end make 400-420whp by only upgrading rods bolt to ARP bolt. A friend of mine is currently making 440 with a b20, arp rod bolts, double h/g and arp headstuds. I would just do that or put in both aftermarket piston/rods.
Adriano</TD></TR></TABLE>
yup its cheap and it works i always ask ppl when was the last time they can say they saw a rod split, crack in half, or anything of that nature. its the rod bolts that go first i believe RSP uses stock rods with arp bolts in their autocross cars
Ericbalanzar
Feb 11, 2015 05:14 PM
hotimportcrx
10
Sep 6, 2005 10:39 PM
Mr. Vapor
Aug 31, 2005 12:20 PM
Slimm-rw-
May 3, 2004 01:06 PM
98civicEX
Aug 19, 2002 02:58 AM
