RUST HELP
Old Jul 4, 2007 | 07:16 AM
TMC_EF's Avatar
Default RUST HELP
I just brought this cb7 and the only problem it had was all the rust . How can I fix this can someone tell me step by step , or if anyone lives in the philly are can do it for me (IM ME)
[IMG][/IMG]
[IMG][/IMG]
Old Jul 4, 2007 | 07:28 AM
perseverance's Avatar
probably sheetmetal/new panels. looks pretty nasty
Old Jul 9, 2007 | 01:33 PM
msinsky14's Avatar
Default Re: (perseverance)
its fixable with sheet metal, just find the right guy, some shops wont do it because it difficult to shape sheet metal and bondo it to match the cars lines, id say ur looking at 1K-1.5K for a shop to do it
Old Jul 9, 2007 | 03:55 PM
sc4dr's Avatar
Default Re: RUST HELP (TMC_EF)
oohhhh thats nasty. I would put new quarter panels, and wheelhouses on it. Otherwise theres a good chance the rust will come back. Anytime you section a outer panel through the middle your left with a seam, and it's hard to seal out moisture.
For a quick fix, if you're not looking to spend as much, have a good fiberglass guy cut out the metal, and use fiberglass sheets and resin to restore the panels. Not ideal, but it'll work for a little while.
Old Jul 9, 2007 | 05:59 PM
msinsky14's Avatar
Default Re: RUST HELP (sc4dr)
when i had my old 4gen prelude de-rusted, i took it to a guy thats been doing frame work and bosy/custom work for 25 years now. he cuts the rust out a full inch beyond the farthest rusted point. then after its welded he grinds down both sides and uses filler, then a sealer, then a primer, and then base/clear. it looked factory and not a bit of rust started up again after a year of having it.
find someone who really knows what they're doing and u shouldnt have a problem.
Old Jul 10, 2007 | 03:51 PM
sc4dr's Avatar
Default Re: RUST HELP (msinsky14)
The only problem with his, is that the rust traveled into his inner panels, and to cut and shape sheetmetal like that is costly. I would charge atleast $1,500 to fix and paint that using raw sheetmetal.
Old Jul 12, 2007 | 10:49 AM
Flashmn's Avatar
They make repair parts for wheel arches, autoparts dealer should have them.
eman96
Paint and Body
Feb 5, 2014 04:41 PM
f20cmx5
Paint and Body
Oct 5, 2010 10:50 AM
DJ Stimpy
Jul 8, 2007 08:49 AM
rexosaurus
Aug 15, 2005 10:14 AM
