What should I do?!
Ive got a fully built GSR block with a B16 head making 12.9 : 1 compression... I was wondering what gap I should make the spark plugs and also what kind you think I should use... Right now we have them gapped at 28 and it seems to be running fine with Irridiums. I also need to know how to jump my ecu to reset the timing from the dizzy. Please anyone good advice is really needed in this situation... And I did search the spark plug issue
What car do you have??
a paper clip or piece of wire works fine, if you have a eg/ek/dc then there is a blue plug under the glove box, towards the air blower motor. It should be in a green or blue rubber cover...
Modified by DSRxCandyh22EG at 2:11 PM 7/4/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSRxCandyh22EG »</TD></TR><TR><TD CLASS="quote">What car do you have?? </TD></TR></TABLE>
im guessing a 93 hatch
Yes it is a 93 Civic hatch... We fixed the timing and the gapping... I appreciate the help all I need now is to fix the code 16 which is injectors... wiring is good hope its a simple fix.
When you have a fresh rebuild/ build... Is it normal for 3/4s of a quart of oil to burn in about 12 miles and 4 hours of idling? Ive never had a fresh rebuild and assume that the rings just havent seated and that there is quite a bit of blow by... But I dont know for sure...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRHatch93 »</TD></TR><TR><TD CLASS="quote">When you have a fresh rebuild/ build... Is it normal for 3/4s of a quart of oil to burn in about 12 miles and 4 hours of idling? Ive never had a fresh rebuild and assume that the rings just havent seated and that there is quite a bit of blow by... But I dont know for sure...</TD></TR></TABLE>
thats not good.
thats not good.
EG2Driver
Sep 4, 2006 07:35 PM
SdGSR01
Sep 16, 2004 02:55 PM
jinxproof99
Aug 7, 2001 03:54 PM
