99 si running like crap
Old Jul 3, 2007 | 08:43 PM
LilKrnThugBoi253's Avatar
Default 99 si running like crap
I have a 1999 Civic si. My alternator went out, so I replaced the alternator. After replacing the alternator, I replaced the battery also. Then I started my car. I drove it down the street, then my speedometer starts tweeking out and from my ecu, it starts clicking. So I checked the alternator fuse under the dash to see if it was blown. It wasn't blown, so then I checked if my ecu was fried, so I jump my car to a obd1 p72, car turns on with a check engine light and turns off. Then i use a p28, and the same thing happens. I really don't know what it can be now. I also checked if everything was grounded and every is grounded. Does anyone know what might be the problem? thanks
Old Jul 3, 2007 | 09:33 PM
SuperSteve737's Avatar
Recheck your grounds, make sure the alt. plugs are all the way in.
Old Jul 3, 2007 | 09:52 PM
924doorEG's Avatar
sometimes when you put in a new alternator the starter tends to go out
Old Jul 3, 2007 | 10:33 PM
ev13lf's Avatar
Default Re: (924doorEG)
could be an eld.
check your fuses, and get ready to bust out the multimeter...
Old Jul 4, 2007 | 12:33 AM
MidwestCivic's Avatar
its the thermostat ground
Old Jul 4, 2007 | 05:32 AM
Si Jeff's Avatar
Default Re: (ev13lf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ev13lf &raquo;</TD></TR><TR><TD CLASS="quote">could be an eld.
check your fuses, and get ready to bust out the multimeter...</TD></TR></TABLE>+1
Old Jul 4, 2007 | 10:31 AM
thanks for the advice everyone!
wspencer5
Honda Civic (2001 - 2005)
Jan 3, 2015 02:10 PM
djrubio
Jul 18, 2009 07:41 PM
EG6R
May 10, 2007 01:57 PM
macsmurray
12
Jun 14, 2005 02:36 AM
z1p
Nov 8, 2004 05:49 AM
